WJ No gauges, no windows, won't- pass insp-Please help! - JeepForum.com
 1Likes
post #1 of 36 Old 02-21-2020, 09:19 AM Thread Starter
TBUSMC61
Wj WJ No gauges, no windows, won't- pass insp-Please help!
I have a 2001 WJ that started having problems over a year ago. Started with an intermittent no-start, which I eventually determined was sentry-key related. Also gauges would drop out intermittently. It eventually got worse and worse. Took it to a mechanic, and he said it would be dealer-only. I spent about 1400 dollars at the dealership, and they finally said it was the gauge cluster, and its discontinued, so they can't help. The gauge cluster self-test comes out fine, if that means anything here. I also have used 4 junkyard gauge clusters with no change. I also bought an entire computer set (BCM, PCM, Gauges, SKIM) and installed it in my Jeep, and had all the same problems-no change. I read that broken door wires can cause this, and I couldn't find any broken ones, or grounded out. I also checked all the fuses, and none are blowing. I'm at the point where I wish I could just junk it, but I really can't afford to. If you need any more info, please let me know. If you can help at all, please give me any and all suggestions. I really appreciate everyone here.
TBUSMC61 is offline
post #2 of 36 Old 02-21-2020, 09:34 AM
JGCJeep
Check other wiring. Sounds similar to my problem and it wound up being wires melted together next to the throttle body. I have a 4.0. Good luck.
JGCJeep is offline
post #3 of 36 Old 02-21-2020, 09:40 AM
JGCJeep
How comfortable are you working with a multimeter?
JGCJeep is offline
post #4 of 36 Old 02-21-2020, 09:52 AM Thread Starter
TBUSMC61
I'd say pretty good. If you have an specific tips on finding shorts and grounds in the WJ, I'm all ears
TBUSMC61 is offline
post #5 of 36 Old 02-21-2020, 11:05 AM
LTopher
Check out this thread on grounds, a ton of useful info.
Programmers don't die, they just lose their memory!
His: 2001 WJ I6
Hers: 2011 WK2 V6
LTopher is offline
post #6 of 36 Old 02-21-2020, 11:22 AM Thread Starter
TBUSMC61
Thank you! that's great
TBUSMC61 is offline
post #7 of 36 Old 02-21-2020, 02:35 PM
JGCJeep
Nothing specific. Get the schematics and diagrams and start isolating things.
JGCJeep is offline
post #8 of 36 Old 02-21-2020, 02:36 PM
JGCJeep
Does your fuel pump prime with the KOEO?
JGCJeep is offline
post #9 of 36 Old 02-21-2020, 02:45 PM Thread Starter
TBUSMC61
I'm not sure if the fuel pump primes KOEO, but if you're asking if it starts and runs, it does. The guy I bought it from was zero help (This started about six weeks after I got it) but he told me to send it out to an Ebay seller who reprogrammed the PCM to delete Sentry Key. The gauges were still working intermittently at the time. I got the PCM back, and as advertised it does now start and run. It actually drives okay, for the most part. I hope that answers your question.
TBUSMC61 is offline
post #10 of 36 Old 02-21-2020, 02:47 PM Thread Starter
TBUSMC61
Send the PCM* out to an Ebay seller, if I didn't explain that well
TBUSMC61 is offline
post #11 of 36 Old 02-21-2020, 02:52 PM Thread Starter
TBUSMC61
I do have a schematic, and I ohm-ed out the gauge cluster wires, both front door wires, and the auto-dim mirror wires (all seemed to lead to related systems in the BCM). I didn't find any shorts to ground or two each other on any of those plugs. I would shoot all the BCM wires if I could, but I get lost in that part of the schematic to be honest. Everything seems to hinge on the 'PCI BUS', and I don't really follow.
TBUSMC61 is offline
post #12 of 36 Old 02-21-2020, 03:50 PM
JGCJeep
Does the fuel pump make a noise when you turn the key on engine off when you’re having a stall condition and gauges aren’t working?
JGCJeep is offline
post #13 of 36 Old 02-21-2020, 03:53 PM Thread Starter
TBUSMC61
Does the fuel pump make a noise when you turn the key on engine off when youíre having a stall condition and gauges arenít working?
I'm not 100% sure, but I no long have a stall or no start problem. It starts well with short crank times.
TBUSMC61 is offline
post #14 of 36 Old 02-21-2020, 05:17 PM
JGCJeep
So it always runs and your only issue now is the gauge cluster?
JGCJeep is offline
post #15 of 36 Old 02-21-2020, 11:25 PM Thread Starter
TBUSMC61
Yes, that's right. No gauges, warning lights christmas tree'd. My biggest issue is I have state vehicle inspection here, and they can't pass it if its showing those lights.
TBUSMC61 is offline
