WJ Lift/Tire Submission Thread - Page 5 - JeepForum.com
 73Likes
post #61 of 80 Old 11-11-2020, 06:31 AM
wranglertec
Rough country lifts. Iíve got my self another WJ. 04 limited 4.7. Iím looking at lifting this one. There many kits out there. I noticed that Rough Country 4.0 inch lift use a lower control arm relocation bracket. No one else does. Anyone use there kit?
Sent from my iPhone using Tapatalk
wranglertec is offline
post #62 of 80 Old 11-21-2020, 09:44 PM
CraigMBAx
CraigMBAx's Avatar
Originally Posted by SD Overland View Post
I've updated and replaced quite a few things since my last post in this thread:
Looks fantastic! I'm hot on your heels with the same ideas.
Anything you would change if you did it again?
Is there any reason I shouldn't skip the benchmark and go straight to the long arm kit?
Thanks!
CraigMBAx is offline
post #63 of 80 Old 11-23-2020, 10:49 PM
GriffLvr
GriffLvr's Avatar
Finally pretty much got the lift done, drove it around about 20 miles and it feels pretty good, need to get the wheel centered up but that's for another thread.
IRO foundation series 3'' coil spring lift
IRO adjustable track bar
Bilstein 5100 series shocks
Moog trail boss HD steering stabilizer
New coil spring isolators front/rear
New front stock sway bar links
Addco rear sway bar
No wheel spacers
265/7517 tires, No rubbing yet but only 20 miles in.
GriffLvr is offline
post #64 of 80 Old 12-03-2020, 09:36 PM
elJeepo_00WJ
Originally Posted by geokain View Post
Any rubbing issues with this set up? Was thinking about the same tires for my WJ
Originally Posted by Teddy2 View Post
yes do you have any rubbing? I was looking at the same tire but in 265/70/16
Sorry for the incredibly late reply! Have since sold that Jeep. Rubbing only at full lock with the steering, I'm sure offroad it would rub in some other locations. Picked up another WJ and planning the same setup. Was very pleased with the ride height and ground clearance, those DT8000 shocks sucked and I would absolutely suggest the Bilsteins (haven't used them yet myself). I purchased through Kolak.
why is my jeep always breaking???
elJeepo_00WJ is offline
post #65 of 80 Old 12-06-2020, 04:14 AM
Stay Stoney
Iro critical path long arms
Iro 4 inch springs
Jks adjustable trac bar
Bilstein front 24-185943 for tj with 5.5 lift (they are two inches longer then the ones meant for a wj with 4 inches of lift)
265/75R16
wranglertec likes this.
Stay Stoney is offline
post #66 of 80 Old 12-10-2020, 07:39 AM
gcjeeping
gcjeeping's Avatar
Lift: 6" RockKrawler long arm
Wheels: 15" pacer soft 8's
Tires: 33x12x15 Duratracs
Additional Information:
To much to list
wranglertec and Stay Stoney like this.
_____________
gcjeeping is offline
post #67 of 80 Old 01-06-2021, 11:38 AM
Vic9
Vic9's Avatar
Has anyone on this page used CORE 4x4 Adjustable Control Arms? Thoughts and are they worth the money? Bushings are worn on the stock arms and I think they are about to go...
3.5" of lift, 32" BFG KM's, quick disconnects, Doetsch Tech Shocks
Vic9 is offline
post #68 of 80 Old 01-06-2021, 05:18 PM
wranglertec
Yes I have used them on a TJ Wrangler and an XJ Cherokee. I just ordered rears for my WJ on Monday. Iíve never had an issue with them.
post #69 of 80 Old 01-13-2021, 01:01 PM
browtine
Does anyone know if 15 x 10 inch wheels will fit over WJ brake calipers?
browtine is offline
post #70 of 80 Old 04-10-2021, 04:31 PM
Caish
1987 XJ Cherokee
2000 WJ LAredo 4.0 Selectrack NP242,
4" RC lift,
JK Moabs, with stock 255/75R17 Goodyear Wranglers.
Rust Free, nice leather still, no tears,
Super Nice,
Quit Facebook.
Gab: Jeepers
Mewe: Arkansas Jeeps
my stable:87 XJ, 2k WJ, 88 MJ, 91 YJ, 09 JK...
Caish is offline
post #71 of 80 Old 04-12-2021, 08:07 AM
#1EasyXjer
#1EasyXjer's Avatar
04 GC not lifting can I run 245/75 17 with no rub issues? Thanks.
#1EasyXjer is offline
post #72 of 80 Old 04-12-2021, 11:08 AM
nickfast
Uh, no. That's about a 32" tire.
nickfast is offline
post #73 of 80 Old 04-12-2021, 11:22 AM
Stay Stoney
Wj
Iro 4 inch springs
265/75R16
now i have her on 285/75r16s mile star patagonias
i have yet to do any more trimming or even go flex it out fully but i know its going to rub
spottedfrog likes this.
post #74 of 80 Old 04-12-2021, 05:17 PM
#1EasyXjer
#1EasyXjer's Avatar
My chart says 31.4 inches What is the limit 30.0? 245 65 17 is 29.5 At that I guess the factory size is the largest you can go without lift. THe question was because I could have gotten a great deal on 4 245 75 17 tires.
post #75 of 80 Old 04-13-2021, 05:37 AM
Caish
1987 XJ Cherokee
my Parts rig 04 WJ I slapped a set of 265/75r16 off the JK on it they rub quite a bit, so without trimming, and even removing the foglights doubt the 245/17 will work...
#1EasyXjer likes this.
Quit Facebook.
Gab: Jeepers
Caish is offline
