WJ Jeep won't start - JeepForum.com
post #1 of 6 Old 05-21-2019, 01:53 PM Thread Starter
56BelAir
WJ Jeep won't start
My Jeep won't start. I hear this ongoing clicking sound under my dashboard as my trickle charger charges my battery. Not really sure if the battery is low or if there is a connection issue where the starter won't turn over the engine. I don't see ANY dash lights when I attempt to start the Jeep. Just hear a clicking sound all the time. Please advise
2001 Jeep Grand Cherokee Limited
Red
Spectacular sterosystem
Pretty cool roof rack
4.7 V8
56BelAir is offline
post #2 of 6 Old 05-21-2019, 02:08 PM
DJCantonGA
DJCantonGA's Avatar
I would first make sure your terminals are tightly connected, then have the battery checked. I had a similar issue a few years ago, and it was the battery.
DJCantonGA is offline
post #3 of 6 Old 05-23-2019, 09:18 AM Thread Starter
56BelAir
I took the battery to the shop, it tested excellent. 900 cold cranking amps. I made sure my terminals were cleaned and tight. The car doesn't click over when I attempt to turn the key. I hear some clicking noise in the dash. My power locks do not work with my remote. Seems like something electrical. Thoughts?
Red
4.7 V8
56BelAir is offline
post #4 of 6 Old 05-23-2019, 03:56 PM
Mattyjm
Mattyjm's Avatar
What happens why you try to start it in Neutral with your foot on the brake pedal? Any difference?
2000 Laredo. Now a donor vehicle to my
2002 Laredo. Baloo. Currently a work in progress.
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #5 of 6 Old 05-23-2019, 05:23 PM Thread Starter
56BelAir
When I put it in neutral and try to start the car, nothing happens. No dash lights, no click. My door locks do work though on all 4 if I use the master switch. Not sure if that means anything.
56BelAir is offline
post #6 of 6 Old 05-24-2019, 09:54 AM
DeepCreekWJMJ
Do your brake lights work? Had the brake switch go out in a work truck once, and it clicks when it goes bad and won’t let you start the vehicle (this wasn’t a Jeep so not sure if it would apply here but it should be an easy fix if that’s the issue). And the switch was located behind the pedal where it connected to the rod, if that’s where the sound is coming from.
DeepCreekWJMJ is offline
Jeep 4.0 I6 engine crank no start, no spark, no Fuel Ridettu21 Jeep CJ Forum 11 02-19-2019 03:39 PM
Jeep won't start after trying to start it while in gear MonkMonk71 YJ Wrangler Technical Forum 6 07-01-2018 02:20 PM
The 5 Jeep States Of Being Psyclops Wrangler General Discussion 6 03-23-2018 10:50 PM
I took idle air control off to clean and now Jeep won't start Jwag14 ZJ Grand Cherokee Forum 6 02-28-2018 08:22 AM
Jeep wont start! doesn't even click!!! gollas108 TJ Wrangler Technical Forum 4 12-28-2017 10:51 AM
