Wj front upper control arm axle bushings - JeepForum.com
 2Likes
  • 1 Post By juan_carlos__007
post #1 of 12 Old 11-30-2020, 05:17 PM Thread Starter
speednjay
speednjay's Avatar
I gotta change these things out. They’re bad. I can wiggle them around with my hand no effort. I changed the lower arms and things were an inch off of alignment.
I was going to order a poly set so I wouldn’t have to press the old sleeves out. Just leave the metal sleeves in and clean the rubber out. Has anyone installed the poly bushings? I’m assuming that I won’t need to press the sleeves out Correct? Trying to make this Job as easy as possible for me
speednjay is offline
post #2 of 12 Old 12-01-2020, 10:23 AM
coldspit47
It's going to be a lot easier to scrub out the old rubber if you press the sleeves out...but seems like it's possible to install without pressing them out.
JEEP. making mechanics out of ordinary folks since 1940.
coldspit47 is offline
post #3 of 12 Old 12-01-2020, 12:43 PM
xcaliber81
xcaliber81's Avatar
Man my bushings were trash. the sleeves came out by hand I took a chisel and hammer and smashed in 1 side and it came out, the whole deal was about an hour.
xcaliber81 is offline
post #4 of 12 Old 12-01-2020, 02:04 PM
Frambo
I put poly in so I'd never have to do it again. It's made the ride a little more firm. I'm thinking about swapping the arms back to rubber but leaving the poly in the axle bushes.
I had my garage do it and they pushed / destroyed the old sleeves out, ordered some new cheap *** bushes and used the sleeves from those.
Frambo is offline
post #5 of 12 Old 07-25-2021, 03:11 AM
juan_carlos__007
Which manufacturer makes these in polyurethane? I like nolathane cause they were low price for the sway bar bushings but they dont carry these ones that go mounted on the axle.
Sent from my NX629J using Tapatalk
juan_carlos__007 is offline
post #6 of 12 Old 07-26-2021, 05:13 PM
Frambo
https://superprousa.com/collections/...edo-esi1392973
Superpro - they make the best poly bushes. Minimal increase in NVH and no squeaking!
Frambo is offline
post #7 of 12 Old 07-27-2021, 07:47 AM
Sangster
Sangster's Avatar
If you're not lifted, just get replacement arms with bushings already in them for same or less $.
2004 WJ Overland
2014 WK2 Overland
Sangster is offline
post #8 of 12 Old 07-27-2021, 01:08 PM
juan_carlos__007
Cool I already had ordered some rubber ones from crown automotive we'll see how long they last since control arms are polyurethane from core4x4. I need to repair these because I have death wobble due to caster being off and dont want to adjust it until everything is tight.
Sangster likes this.
post #9 of 12 Old 07-28-2021, 12:26 AM
bezzat
Supper pro its good , but not enough
to me it lasted a year and a half
buy this and you will not regret
https://www.ironrockoffroad.com/prod...cartridge.html
2004 JEEP GRAND CHEROKEE 2.7L CRD
bezzat is offline
post #10 of 12 Old 07-28-2021, 06:18 AM
NeedBoost
I agree that Superpro makes some of the best poly bushings out there, I would not recommend them in this situation if you want much flex out of the them. Poly does not flex much at all and when you try to get it to flex much it will start to bind. So would not recommend if you do any offroad, but should be fine on a daily.
NeedBoost is offline
post #11 of 12 Old 07-28-2021, 07:32 AM
Frambo
I've had Superpro bushes in for 80,000 miles and they've only just worn out. But those IRO ones are cool! Are they stiff like Superpro or are they more soft like rubber?
Agree that superpro won't give you flex but why would you want flex in your upper arms bushes? Actually I guess they're pretty central on the vehicle so axle articulation means that the arms want to twist slightly.
I actually did what I was thinking about back in January and left poly in the axle bush mount and rubber in the arms.
Overall drive is much nicer now!
Frambo is offline
post #12 of 12 Old 08-16-2021, 02:00 AM
juan_carlos__007
I ordered those from Iron rock since the rubber ones flex too much and I believe might be cause for death wobble. They cost the same as superprousa, heavier duty, and easier to service than having to press again. Thanks
bezzat likes this.
