WJ engine swap? - JeepForum.com
post #1 of 13 Old 07-06-2017, 12:37 PM Thread Starter
LukeSwitzer
WJ engine swap?
Hello everyone! I learned my lesson from my last post, and searched the forum for answers to my new question, but I was unable to get a complete picture of what I wanted to know. So without further adieu, here we go.
Last month, I got a deal on a 2004 Grand Cherokee Laredo with about 140,000 miles on it. It is a Selectrac 4x4, with an good running 4.0 six cylinder. It has a couple of problems, the main one being a wearing out transmission. I could have the good 'ole four speed rebuilt, but I have had an idea I'd like to get some input on.
Has anyone swapped in a 4.7 liter (standard or HO) V8 from another WJ into one that came with an Inline 6? I realize this would require changing transmissions, and since my old one is on the way out anyway, why not upgrade to the 45RFE while I'm at it AND get more power?
Further, if anyone has done this swap, how successful was it? Would it be a huge hassle for the average mechanic? Could I do it myself provided I had the proper tools and the time to work on it? I know that one must modify the drive shafts and switch out the output shafts from the t-case. I'm also gonna assume one would need a new wiring harness and new control modules for the five speed Tranny and V8 and new mounts for the engine. Would peripherals like the radiator have to be swapped out? What else must be done?
Also, since I've come this far, would one be able to drop in a 4.7 from a newer Chrysler vehicle? I heard that the 4.7s from 2008 forward made north of 300 horsepower. This sounds very attractive, and I'm pretty sure that in the WK the engine was mated to a very similar six speed transmission as what was used in the WJ. I have done some pretty thorough googling and I can't find evidence of this particular swap anywhere.
I am aware this would be a fairly expensive proposition, but I have already sourced a 2004 V8, tranny (with around 120,000 miles), and both the control modules from a local guy for 1500 bucks. After that--as far as I can figure--all I would need is a new harness, engine mounts, and a custom made set of driveshafts.
Anyways, just wondering if anyone out there has done this or seen it done. Any and all input is most welcome.
Luke.
LukeSwitzer is offline
post #2 of 13 Old 07-06-2017, 08:05 PM
RonSwanson
2003 WJ
Have you considered an LS swap?
RonSwanson is offline
post #3 of 13 Old 07-06-2017, 08:14 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Yes, swap in a Chevy motor, rewire the entire computer, trans, transfer case...
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 13 Old 07-06-2017, 08:32 PM
xcaliber81
xcaliber81's Avatar
Hunter
Piece of cake lol.....
xcaliber81 is online now
post #5 of 13 Old 07-06-2017, 08:35 PM
xcaliber81
xcaliber81's Avatar
I don't know about you but I like my wj with working seats gushes lights you know all the important + creature comforts.
post #6 of 13 Old 07-08-2017, 02:31 PM Thread Starter
LukeSwitzer
Yeah fellas, not really looking to swap in anything that's gonna require a bunch of custom fabrication and several thousand dollars. I'm in college lol. Anyone else got any input?
post #7 of 13 Old 07-08-2017, 02:43 PM
kg6mov
Hears the voices
kg6mov's Avatar
The short path is to get a V8 WJ and swap your mods/interior. At the point of trying to shove a V8, trans, and all the associated electrical into the thing you'd honestly be looking at almost as much work as an LS. The only easy way to do either swap is to have the donor there, and at the point of buying a donor wj, just use the new wj.
kg6mov is offline
post #8 of 13 Old 07-08-2017, 02:44 PM
kg6mov
Hears the voices
kg6mov's Avatar
All of that works on the LS WJ in our club, at least it does when he isn't blowing the motor up with too much boost.
kg6mov is offline
post #9 of 13 Old 07-09-2017, 07:03 PM Thread Starter
LukeSwitzer
Alrighty boys. Got ya. Does anyone have a link they can drop to that build thread for the LS-swapped WJ? It'd be appreciated.
post #10 of 13 Old 07-10-2017, 08:53 AM
tybarious
tybarious's Avatar
There's a couple if you do a google search but I do remember there was group on FB about a LS swap.
Ah found it https://www.facebook.com/LSXWJ/
tybarious is offline
post #11 of 13 Old 10-10-2021, 12:22 AM
peaston
peaston's Avatar
Hi Hunter,
Mine dropped the valve seat & pop the rocker.
04 4.7L HO, what do you suggest at this moment? in case I want to keep driving it for another 6 yrs or so. 155k right now.
Appreciated,
Gary
peaston is offline
post #12 of 13 Old 10-10-2021, 08:41 PM
Golden-Arm
Golden-Arm's Avatar
and while you're at it, why not date a tranny?
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #13 of 13 Old 10-11-2021, 05:53 PM
CraigMBAx
CraigMBAx's Avatar
The motor is junk.
Find another running jeep and part yours out.
1999 WJ Limted - Ex Soccer Mom ride turned Rule 25 Compliant Bike Hauler
CraigMBAx is offline
