WJ -> 4 door Comanche - JeepForum.com
post #1 of 18 Old 11-10-2015, 10:47 AM Thread Starter
swiftnomad
Xj WJ -> 4 door Comanche
I've made up my mind that this weekend I'm going to do something I never done before and cut up my jeep.
GOAL:
WJ -> 4 door Comanche. I wanted a 6-foot bed though so I don't know how that can happen with drivetrain or anything. What do you suggest?
swiftnomad is offline
post #2 of 18 Old 11-10-2015, 10:50 AM
ChrisHager
ChrisHager's Avatar
Well, how much of the WJ do you want to keep? Are you using only the body/unibody and attaching a bed behind the second row of seats then putting a whole new drivetrain under it?
I'm getting ahead of myself. Here's an even better starting question - Have you ever done something like this before?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 18 Old 11-10-2015, 11:46 AM
jpat30
A la Brute?
In to see where this goes for sure
-Carpe Diem Phil 1:20
jpat30 is offline
post #4 of 18 Old 11-10-2015, 01:50 PM Thread Starter
swiftnomad
Never done anything like this before but I have the tools. I'm thinking of keeping the front half and adding a bed behind.. and hopefully use the tailgate like the current jeep. I honestly don't know.
I'd like to keep the unibody but I don't like how small the bed is. It's just sheet metal so we will see what I end up doing. What would you do?
post #5 of 18 Old 11-10-2015, 02:43 PM
ChrisHager
ChrisHager's Avatar
Personally, unless I had disposable time and money, I don't think I'd try to turn the WJ into a truck. That's just me though.
I think you're going to find this to be quite the project. I doubt I'll be much of any help but I'll definitely stick around to see what you come up with. Good luck!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6 of 18 Old 11-10-2015, 05:48 PM
ShinyWJ
Please don't drive the end product on public roads. Thank you!
But good luck in your endeavor!
2002 WJ Limited | 4.7 | Quadra-Drive | Inferno Red Pearl | Dark Slate Gray
ShinyWJ is offline
post #7 of 18 Old 11-10-2015, 07:23 PM
Highschool_WJ
Highschool_WJ's Avatar
My recommendation would be based on your fabrication/ body work skills. If you want a longer bed you're gonna have to extend the frame and fab up all new rear fender as well as fab new control arm mounts to the new section of the frame, new brake lines, driveshaft, move the gas tank, and the list goes on.
Or go with a two door version, like this
So if you have minimal experience in fab and body work I would recommend going with a short bed version such as this
If you have no experience I would recommend just buying a small 4 door truck and modifying it to work as well as the WJ would.
But to help out, if you search chopped WJ on google you'll find a few threads with different examples with write ups on some of them.
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #8 of 18 Old 11-10-2015, 07:35 PM
gcjeeping
gcjeeping's Avatar
_____________
gcjeeping is offline
post #9 of 18 Old 11-10-2015, 07:36 PM
braddf
I think that's the only one I have ever seen that turned out halfway decent
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #10 of 18 Old 11-10-2015, 09:25 PM Thread Starter
swiftnomad
Thanks for the search term so I can find stuff on google. I was searching for wj truck conversion, but I didn't find anything like these pictures. Chopped WJ is giving better results. Now I'm second guessing this decision. Hmm
post #11 of 18 Old 11-17-2015, 07:32 AM
dlundblad
2003 WJ
Do they not have any Comanches or other Jeep trucks down in Mexico?
03 WJ Laredo 4.Sl0w
2" BB-Overland Skids
IPF 868 lights-197K
245/75/16 GY DuraTracs
dlundblad is offline
post #12 of 18 Old 11-17-2015, 07:20 PM
messiah
2003 WJ
OK, I don't get it. I mean the reason for doing this? To me at least, those chopped vehicles all look awful. Some were done better than others, but none are something I'd be seen in public with. Is the idea to make a grand cherokee ugly? What would the purpose be of doing this?
messiah is offline
post #13 of 18 Old 11-17-2015, 07:29 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Good thing its not your jeep and you don't have to drive it. Lets keep the creative train going and keep negative, subjective comments like these to a minimum. Hopefully this thread goes somewhere. Id like to see what the OP can come up with
~James
ezflip is offline
post #14 of 18 Old 11-18-2015, 02:30 PM
PeteYJTJ
I kinda dig this. Cut out the top of the roof over the driver and front passenger, and make a soft top like a TJ Unlimited...... A WJ 2-door Unlimited Softop.
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #15 of 18 Old 11-18-2015, 03:57 PM
nickfast
How much strength do you lose, putting a big hole in the frame structure like that?
It's done somewhat commonly on Cherokees, and there is a tone of reinforcement that has to be done afterward to keep the rig from twisting into a pretzel the first time you hit the gas...
nickfast is offline
