Wj 2nd gear shifts a bit hard - JeepForum.com
post #1 of 7 Old 08-01-2021, 12:00 PM Thread Starter
Carrilloaluis
Hello everyone, I have a 2004 overland with 150k, just today in the morning 2nd gear shifts a bit hard. Tranny fluid was changed at 110k. Any suggestions were can I start?
Carrilloaluis is offline
post #2 of 7 Old 08-01-2021, 12:02 PM
WJ60
WJ60's Avatar
Were both filters changed with the fluid?
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is online now
post #3 of 7 Old 08-01-2021, 03:03 PM Thread Starter
Carrilloaluis
Good question, I took it to a mechanic shop because it was going on limp mode. He fixed it and told me he change the fluid.
post #4 of 7 Old 08-01-2021, 04:07 PM
WJ60
WJ60's Avatar
Have you checked for codes on an OBD2 reader?
WJ60 is online now
post #5 of 7 Old 08-01-2021, 07:22 PM Thread Starter
Carrilloaluis
I did, no codes. Seems is only doing it when cold.
post #6 of 7 Old 08-01-2021, 08:04 PM
jtec
jtec's Avatar
2014 JK Wrangler
did you use a quality SCANNER to ck codes?
what was the issue with it going intolimp mode- codes?
jtec is offline
post #7 of 7 Old 08-02-2021, 12:37 PM
MuloChico
MuloChico's Avatar
2006 WK
Just a wag, but have you done the motor/trans mounts? My '99 was getting worse, unrelated I noticed that my mounts were toast so I changed them out. The shifting between gears was noticeably better (especially in low range, smooth now). The engine/trans was torqueing on the mounts making it seem like the trans was shifting hard. With that many miles/years it could be transmission, but check your mounts.
MuloChico is offline
