wiring - JeepForum.com
post #1 of 9 Old 02-24-2020, 12:46 PM Thread Starter
Artie Bacardi
wiring
I have 2004 wj,just put in a used engine,can somebody help with these connectors.It is a 4.7l HO.They are on the left side by the engine rear,standing in front of the truck.
Artie pics 381.jpg   Artie pics 382.jpg   Artie pics 383.jpg   Artie pics 384.jpg   Artie pics 385.jpg
Artie Bacardi is offline
post #2 of 9 Old 02-24-2020, 02:08 PM
Double E
Double E's Avatar
Transmission control module? I think it goes into the black box mounted on the firewall.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 9 Old 02-24-2020, 06:08 PM
Bigrigr
Bigrigr's Avatar
Was your original engine also an HO? Im no expert, but are those the knock sensor connectors? Only the HO version has them.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 9 Old 02-25-2020, 12:59 PM Thread Starter
Artie Bacardi
wiring
Computer told me trans,abs and engine,I will go out to shop and check what you two told me.Thanks,Artie
post #5 of 9 Old 02-25-2020, 01:31 PM
jtec
jtec's Avatar
2014 JK Wrangler
confirm that is left side as in DRIVER side?
jtec is offline
post #6 of 9 Old 02-25-2020, 02:35 PM Thread Starter
Artie Bacardi
wiring
Put in a 4.7 h.o. Where do I plug in the knock sensor connector into?? Trans plug I dont know if the is enough wire?? Artie Thanks
post #7 of 9 Old 02-25-2020, 02:46 PM Thread Starter
Artie Bacardi
left side standing in front of Jeep.So,passenger side.Hope that helps.
post #8 of 9 Old 02-26-2020, 01:49 PM Thread Starter
Artie Bacardi
Harness
I have both sets of wiring harness,their is no spot on both sets to put on a knock sensor plug.Does this make any sense??
post #9 of 9 Old 02-26-2020, 05:01 PM
Bigrigr
Bigrigr's Avatar
was the engine you took out an HO?
Bigrigr is offline
