Window making horrible grinding noise - JeepForum.com
post #1 of 4 Old 08-15-2012, 06:19 PM Thread Starter
gcsmorgan
Unhappy Window making horrible grinding noise
Today I was rolling down my driver side window and almost immediately I hear a horrible grinding/scratching noise. When I rolled it back up a few streaks appeared that I didn't notice before. I have power locks and windows, and it is a 2002 Jeep GC Laredo Sport... with 177,000 miles. So I guess it's about that time for parts to start failing.
What could this be and is it easily fixable?
2002 Jeep Grand Cherokee Laredo Sport | 4.0L I6 | 2WD | 225-75-R16 BFG Radial Long Trail T/A
gcsmorgan is offline
post #2 of 4 Old 08-16-2012, 08:22 AM Thread Starter
gcsmorgan
EDIT: I decided to give the door a good SLAM to see if it would fix anything.... and it did. I'm not sure what was loose or rubbing up against the window but closing the door extra hard seemed to fix it.
Never knew we had a smiley like this... awesome.
post #3 of 4 Old 08-16-2012, 08:39 AM
2001WJv8
2015 WK
it's pretty easy to open up the door and look around if it happens again, but nice when the simple fix works
"if at first you don't succeed, get a bigger hammer"
2001WJv8 is offline
post #4 of 4 Old 08-16-2012, 06:12 PM
sfjacks1
Sounds like the window regulator is starting to bind up
sfjacks1 is offline
Nv 247 transfer case making grinding/poping noise nicecj7 WJ Grand Cherokee Forum 29 04-06-2020 12:21 PM
Rear tires kinda wiggle, making horrible sound? radryan505 WJ Grand Cherokee Forum 3 03-29-2012 08:56 PM
Horrible grinding sound after 4" lift cmurr03 WJ Grand Cherokee Forum 6 12-19-2011 07:45 PM
WJ making wierd grinding noise, Help! Ljohn221 WJ Grand Cherokee Forum 13 06-13-2011 12:55 AM
need to replace something, making grinding sound! pygocentrus WJ Grand Cherokee Forum 3 09-20-2003 07:05 PM
