Where is pcv valve located on 4.7 ho? - JeepForum.com
 1Likes
  • 1 Post By Falkon
post #1 of 10 Old 09-16-2020, 08:08 PM Thread Starter
iaintslow
Stupid question but where is pcv valve located on 4.7 HO? Is there 1 or 2 of them?
Thanks
iaintslow is offline
post #2 of 10 Old 09-16-2020, 08:38 PM
sdg3205
sdg3205's Avatar
Oil fill cap.
There are some PCV breathers on the back of the heads as well.
sdg3205 is offline
post #3 of 10 Old 09-16-2020, 08:59 PM Thread Starter
iaintslow
Hum pcv and breathers? thats strange i want to replace pcv valve is there anything else needs to be replaced as part of pcv system??
post #4 of 10 Old 09-16-2020, 09:58 PM
blueseasons
Remove the oil filler cap and look inside. You will see a hole on the side. Stick your finger on the hole with the engine running, your finger should get sucked against the hole. Engine rpms will drop. If both those things happen PVC is good.
blueseasons is offline
post #5 of 10 Old 09-16-2020, 10:01 PM
Falkon
Falkon's Avatar
Uniblurb likes this.
Falkon is offline
post #6 of 10 Old 09-16-2020, 10:06 PM
Uniblurb
Uniblurb's Avatar
^ Real good info Falkon and I was going to look up some part numbers for him but he never gave the year.
It helps to have the plastic/tubes warm where you're less apt crack or break one. And add a little oil to the PCV o-ring so it seals easily.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #7 of 10 Old 09-16-2020, 10:09 PM
Falkon
Falkon's Avatar
That's from WJ Jeeps Site.
Falkon is offline
post #8 of 10 Old 09-17-2020, 06:13 AM
Uniblurb
Uniblurb's Avatar
Thanks for the location of that info. Believe I pushed my old PVC valve a little before I turned it 1/4 turn counter-clockwise to remove it. Also my hose was split so I installed a new short piece of oil resistant hose with new clamps.
Uniblurb is offline
post #9 of 10 Old 09-17-2020, 12:36 PM Thread Starter
iaintslow
Thanks guys great info. I will replace the valve when i get home. I got new one already its only $4 at pepboys
post #10 of 10 Old 09-18-2020, 06:53 AM
AVR2
Some might consider it overkill, but to avoid damaging the hose (because they never seem to want to pull off the end of the valve without a lot of force) I use my Dremel to cut the old valve, then use pliers to pull the cut end of the valve out of the hose.
AVR2 is offline
