Wheels - JeepForum.com
 1Likes
  • 1 Post By jltibbs
post #1 of 11 Old 04-15-2019, 09:17 AM Thread Starter
CBrendemuehl
Wheels
If I get some 2013 Wrangler wheels with a 56mm offset can they be put on the WJ (50mm offset)?
I also am not certain which direction the offset moves the hub. Would a 6mm spacer be required?
(Getting them for the good tires but may just put the wheels on if there is no real issue.
CBrendemuehl is offline
post #2 of 11 Old 04-15-2019, 09:25 AM
007matman
Wheels should bolt up no problem. If you're planning on larger tires too you'll need a lift.
You shouldn't notice much difference at all from a rim standpoint. I actually have JL rims on my '02 WJ. I needed to use the lug nuts from my old rims.
Sent from my Pixel 3 XL using Tapatalk
007matman is online now
post #3 of 11 Old 04-15-2019, 10:00 AM
jltibbs
I have these on mine with some decent tires & have a little rub. I’d recommend doing the 2” rough country lift. It’s not expensive, & will give the clearance needed.
Sent from my iPhone using Tapatalk
99 JGC "Black & Tan"
jltibbs is offline
post #4 of 11 Old 04-15-2019, 01:02 PM Thread Starter
CBrendemuehl
They are the same sized tires on 16" wheels. From what I can find the only difference between the wheels is the center offset.
That means that height is no issue.
I had the offsets wrong in the OP.
The JK wheel specs as 7JJx16 ET50, which is the 50mm center offset.
https://www.wheel-size.com/size/jeep/wrangler/2013/
The WJ wheel specs as 7Jx16 ET56, which is the 56mm center offset.
@007matman
If you're running the same tires then the offset is 50mm.
https://www.wheel-size.com/size/jeep/wrangler/2018/
If there is rubbing then spacers would be desirable.
It looks like a set of 4 spacers will run about a bill on eBay.
I might keep the old wheels for winter tires.
post #5 of 11 Old 04-15-2019, 02:51 PM
jltibbs
If they’re the same Ø, & you’re running the same size tires, there should be no reason whatsoever for spacers. There’s only a 6mm (less than a 1/4”) of difference.
Sprung99GC likes this.
jltibbs is offline
post #6 of 11 Old 04-16-2019, 07:30 AM Thread Starter
CBrendemuehl
I hope you plugged your phone in. :-)
post #7 of 11 Old 04-16-2019, 08:08 AM
jltibbs
Haha. That’s why it was on low power mode.
That website (will they fit) has been a great tool for me over the years.
jltibbs is offline
post #8 of 11 Old 04-16-2019, 09:24 AM
EHUDPOWER55
Does it really help to have wheels offset or is that just bec he's putting the other rims on it?
EHUDPOWER55 is offline
post #9 of 11 Old 04-16-2019, 09:28 AM
jltibbs
That image just shows how the new rims will set vs the old rims.
jltibbs is offline
post #10 of 11 Old 04-16-2019, 09:39 AM
EHUDPOWER55
I get that but just asking in general
post #11 of 11 Old 04-16-2019, 12:19 PM
jltibbs
Wheels
Gotcha. It really depends on what look you’re trying to achieve. If you notice on some vehicles, the rear wheels appear to be more inset than the front. So, if you’re looking to make the front & rear wheels flush, you may have to run a staggered setup.
To put my words to pictures, here’s my case. This was my 94 Q45. I know it’s not a Jeep, but it explains what I said.
This image shows the difference in the front & rear. The wheels were matched (18x7.5, +35).
This image shows the correction with different wheels (front: 17x8, +5; rear: 17x9, +18). The rear wheel is 1” wider, but has 1/2” lower offset, which then creates a flush appearance.
This image is just because I like the picture, & this was the way I had it setup before I sold it.
I was able to determine what I needed using the site mentioned above, & a measuring tape.
jltibbs is offline
Get $300 Back with New Rugged Ridge Wheels Offer! CARiD CARiD.com 0 10-24-2018 05:38 AM
Save Big with Pro Comp - Wheels and Tires Summer Offer! CARiD CARiD.com 0 07-09-2018 08:36 AM
Are wheel spacers necessary with JK wheels on a WJ? RobGADV WJ Grand Cherokee Forum 8 04-21-2018 08:06 PM
Method Race Wheels at 45% OFF - don't miss! CARiD CARiD.com 0 03-27-2018 05:15 AM
RockAuto Now Offers JTE Replacement Wheels! RockAutoLLC RockAuto 0 02-15-2018 12:22 PM
