Wheel spacers needed? - JeepForum.com
post #1 of 5 Old 10-22-2021, 09:10 PM Thread Starter
flashover52
I have a completely stock 99 WJ. I am going to buy some used BFG KO2's tomorrow, size 255/70 r16's which from what I've read, should fit okay.
I also found a set of hub centric wheel spacers, 1.5" wide; used for $50.
Should I buy the wheel spacers for that price in case I need them or do folks think the stock wheels and those tires will work without rubbing?
flashover52 is offline
post #2 of 5 Old 10-22-2021, 09:19 PM
007matman
You should be fine. The spacers might actually require a little lift as they modify the radius.
Sent from my SM-G981V using Tapatalk
007matman is offline
post #3 of 5 Old 10-23-2021, 03:24 PM
mdwildcat04
If those tires rub, its likely to be on the outside of the fender well, and those spacers are likely to make it worse.
mdwildcat04 is offline
post #4 of 5 Old 10-24-2021, 06:15 AM
Delta0
If the price on the spacers is very nice, I suggest you buy them.
On the basis you can flog them later without loosing much if any.
Delta0 is offline
post #5 of 5 Old 10-26-2021, 08:48 AM
GmanWJ
GmanWJ's Avatar
You will not need spacers to run those tires
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
