Wheel bearing assembly removal - JeepForum.com
 12Likes
  • 2 Post By rjbruzan
  • 1 Post By GmanWJ
  • 1 Post By Mattimus_LV
  • 1 Post By rep-tile
  • 1 Post By Bigrigr
  • 1 Post By coldspit47
  • 1 Post By TheJeepSkate
  • 1 Post By Swiff
  • 1 Post By Bigrigr
post #1 of 14 Old 05-20-2020, 10:16 PM Thread Starter
NWDC
NWDC's Avatar
Anyone have tips on getting the wheel bearing assembly off the knuckle?
I was able to remove all 3 bolts and loosen the shaft nut with no problems but the face of the assembly seems to be fused pretty tight to the knuckle...
NWDC is offline
post #2 of 14 Old 05-20-2020, 10:40 PM
rjbruzan
Hit it with a BIG hammer. Many times! Then hit it more.
SoCal2004wj and NWDC like this.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 14 Old 05-20-2020, 11:54 PM
GmanWJ
GmanWJ's Avatar
Saw a trick one time where you get an old long sacrificial bolt and screw it into one side of the hub but not all the way, let it hang way out there, then turn the steering wheel and the bolt contacts the axle and pops the hub off. Have not tried it myself, mine came right off.
Otherwise ... PB blaster and a hammer. Maybe even a cold chisel if you are brave.
NWDC likes this.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #4 of 14 Old 05-21-2020, 12:17 AM
Mattimus_LV
Mattimus_LV's Avatar
Thread the lower 2 bolts back in about halfway, throw a deepwell 1/2in socket (or use a regular 1/2in socket with a short extension bar) on the head of one of the bolts, start the engine and turn the wheel slightly to the side so the socket makes contact with the "C" of the axle.
If you've got someone to help, it's easier.
Keep turning just a hair so you're using the steering to break the bearing loose.
If you have to, swap the socket to the other lower bolt and turn the wheel the other way.
Just don't get wild and crank the wheel over, or you'll screw things up.
Once you've got the bearing assy out, clean all the mating surfaces really good and apply anti-seize before you put the new one in. It'll save some heartache next time you've got to pull the wheel bearing.
NWDC likes this.
2004 WJ Overland
Mattimus_LV is offline
post #5 of 14 Old 05-22-2020, 12:07 AM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
I actually used that trick once on my XJ after pounding that bastard with a sludge hammer over and over did absolutely nothing. It was like it was fused. Using the power steering and an extension wedged against the frame, it popped right off. Nothing beats hydraulic power. The only thing is it bent my control arm a bit, nothing major. Just need to be careful where you're pressing that bolt against.
Maybe another option. Some guy on the internet sells what he calls the hub buster.
NWDC likes this.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is offline
post #6 of 14 Old 05-22-2020, 02:37 AM
Bigrigr
Bigrigr's Avatar
That hydraulic trick sounds awesome! I gotta try it someday...
If you dont wanna try to hydraulic it out, just get a couple extra long bolts to go in place of your factory hub bolts, leave them loose, and beat them on the head with a big hammer, or air hammer. I have seen many people try to beat the hub flange without any luck. You gotta get your force directed at those hub bolt holes to do any good, plus it helps alot if you were planning on keeping the hub and bearing assembly. Doing it this way wont hurt the bearing. I still have several sets of different length and diameter bolts I kept just for this purpose in my rollaway box at home.
NWDC likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is online now
post #7 of 14 Old 05-22-2020, 08:31 AM
coldspit47
If your bearing isn't completely separated a slide hammer should help. can also leave PB blaster or acetone & ATF soaking overnight. Can also try deadblow hammer to hit the edges of the flange - not the face of it toward or away from the vehicle, but the rim of the flange itself.
NWDC likes this.
04 WJ NV242, IRO 3in, bilsteins, IRO adj UCAs/LCAs/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
post #8 of 14 Old 05-22-2020, 09:24 AM Thread Starter
NWDC
NWDC's Avatar
I ended up getting it off but it was a PITA. I used a combination of hammer to the flange, chisel, punch where I could, and pb blaster but it took at least an hour of pounding. I had a new hub bearing assy. to install so I wasn't worried about damaging the hub flange. I used anti seize on the mating surfaces when I installed the new one, so it hopefully won't be so bad pulling it off next time. I spent ~80% of the time on removal and probably 20% on install.
Does anyone know the exact bolt size/dimensions for those 3 hub bolts to the steering knuckle? I think it would be helpful if I had some for next time so that I could just slide those in and tap them to knock the hub loose.
NWDC is offline
post #9 of 14 Old 05-22-2020, 03:09 PM
coldspit47
Per FCA brake diagram, they're M12x1.75x65.00, hex flange head.
NWDC likes this.
post #10 of 14 Old 05-22-2020, 06:40 PM
TheJeepSkate
TheJeepSkate's Avatar
A big hammer usually works when you work your way around the lip. Do yourself a favor for next time and slather the knuckle with anti-seize before putting the hub back in.
NWDC likes this.
TheJeepSkate is offline
post #11 of 14 Old 05-22-2020, 10:54 PM
Mattimus_LV
Quadratec has replacements, just pick which price you want to pay.
https://www.quadratec.com/categories...s_nuts_washers
I'm in the habit that when I buy replacement wheel bearings, I buy new bolts to go with them.
NWDC likes this.
2004 WJ Overland
post #12 of 14 Old 05-23-2020, 10:48 AM
Swiff
I used a bottle jack behind the hub.
NWDC likes this.
Derek
2k WJ Laredo - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
post #13 of 14 Old 05-24-2020, 03:54 AM
Bigrigr
Bigrigr's Avatar
Good plan, then hold onto the old ones for the next wheel bearing removal.
NWDC likes this.
post #14 of 14 Old 05-26-2020, 06:01 PM
dodger889
dodger889's Avatar
remove the big nut in the middle of the spindle. then try tapping a chisel around the spilt.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
