What size is my oil drain plug? - JeepForum.com
 5Likes
post #1 of 24 Old 10-13-2021, 03:23 PM Thread Starter
HarveyCat
HarveyCat's Avatar
I want to replace it with a cap that has a built in valve to make changing easy with less mess. Size seems to be 1/2 20. Is this correct and has anyone used things like these? Please see attached photo.
I have a 2003 Laredo 4.0L GC WJ
HarveyCat is offline
post #2 of 24 Old 10-13-2021, 06:00 PM
xcaliber81
xcaliber81's Avatar
I think it will still be the same amount of mess. I have more faith in my drain plug.
mak_v8 and WJ60 like this.
xcaliber81 is online now
post #3 of 24 Old 10-13-2021, 07:11 PM
Brallen86
Brallen86's Avatar
2003 WJ
Check out Fumoto instead. Much better for that type of application. I have them on 3 vehicles, gonna add one to my trans pan in the future as well. I typically order mine through Chris of Watson Synthetics. Chris will know what one you need
Vaskania likes this.
-03 WJ Limited; Check out my
Brallen86 is offline
post #4 of 24 Old 10-14-2021, 06:42 AM
Mr. Bitey
Mr. Bitey's Avatar
^^^^^THIS^^^^^
I love the Fumoto drain! Inversely, I tried a Dorman drain that made me nervous as to how little it took to open, collected trail debris, and spouted like a sprinkler head when you did drain it. Piece of garbage - avoid.
Back to Fumoto. 5 stars. Have one on almost all my vehicles now. https://www.fumotousa.com/cars-picku...erokee-4-0l-l6
On my 4.7, I added the elbow that pops in only when you drain. It better directed the stream to a drain pan. It has barbs for a hose, but I did not require one. The 4.0 might not need it at all - not sure how your drain pan is shaped. https://www.fumotousa.com/all-products/sl-10.html
2004 WJ, 4.7 N, daily driver.
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (in progress)
1974 AMC Gremlin X, 440 6bbl (trailer queen, 9.466et @ 144mph)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #5 of 24 Old 10-14-2021, 04:57 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Fumoto it is. BTW - what oil filter do you guys use? I use Rotella T6 5/40 oil.
post #6 of 24 Old 10-15-2021, 06:22 AM
Mr. Bitey
Mr. Bitey's Avatar
I use Purolator PBL30001 on my 4.7. It's a larger filter than OEM, and bumped my oil capacity by almost a full quart. The 4.7 has notoriously small oil drain back holes in the head, so when you are really on it the valve covers are literally filling with oil. I figured the extra capacity can't be bad a bad thing.....
WJ60 likes this.
post #7 of 24 Old 10-15-2021, 11:03 AM
Brallen86
Brallen86's Avatar
2003 WJ
I'm an Amsoil guy, use it in everything from my jeeps to my toys where I can. Started off as a preferred customer and became a dealer last year. Really like their products and the rebuild is getting nothing but Amsoil aside from some of the breakin fluids that Amsoil doesn't offer but the filter I use is the EAO42
leadsled jeep likes this.
post #8 of 24 Old 10-15-2021, 05:17 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Will the Purolator PBL30001 fit my 4.0l?
post #9 of 24 Old 10-15-2021, 06:13 PM
WJ60
WJ60's Avatar
A search of Rock Auto shows the same filters being used on both the 4.0 and 4.7
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is online now
post #10 of 24 Old 10-15-2021, 08:02 PM
leadsled jeep
leadsled jeep's Avatar
Ditto on Amsoil. 30years now and far more miles per spent dollar.
For a WEAK and IGNORANT people, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #11 of 24 Old 10-17-2021, 03:05 AM
rjh41388
When I worked at the dealership I was pretty particular about the oil I used. I was a whatever came out of the pumps for free guy. I didn’t pay for oil or filters for 10 years
rjh41388 is offline
post #12 of 24 Old 10-17-2021, 12:04 PM
Brallen86
Brallen86's Avatar
2003 WJ
Correct. Funny enough I'm running a ford focus filter on my XJ with the 4.0 though as I removed the 90 degree adapter and the factory filters hit the motor mounts and punch a hole in it...only took 3 factory filters before I figured this out haha. The focus filter (i think it's the 2.0 or 2.3 w/turbo I I sourced from) is also rated for larger V8s above 5L just FYI
post #13 of 24 Old 10-17-2021, 12:36 PM
Delta0
Purolator show 3 filters for the 4.7 Harvey.
https://www.pureoil.com/en.html
Delta0 is offline
post #14 of 24 Old 10-17-2021, 12:45 PM
Delta0
I suspect there's a fly in the ointment of your logic Mr B.
From my end of the microscope, no matter how big (or small) your oil filter is, it won't make any difference to the amount of oil in your sump.
The only difference I can foresee is that more oil means a longer time to come up to temp on cold days.
Delta0 is offline
post #15 of 24 Old 10-17-2021, 07:02 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Originally Posted by rjh41388 View Post
When I worked at the dealership I was pretty particular about the oil I used. I was a whatever came out of the pumps for free guy. I didn’️t pay for oil or filters for 10 years
Ok - but when you are paying for it - do you think Rotella 5w40 (T6) - is best for these?
