What is going on with my rear wiper? - JeepForum.com
 2Likes
post #1 of 32 Old 09-11-2020, 04:09 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Sorry it id sideways - also can't figure out how to get window washer fluid to shoot out. Haha
https://youtu.be/rPP7EgIxdk0
HarveyCat is offline
post #2 of 32 Old 09-11-2020, 11:14 PM
Bigrigr
Bigrigr's Avatar
That sounds terrible, better get that inside panel off on the tailgate and check that out. Could be the motor, or the mechanism its attached to.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #3 of 32 Old 09-12-2020, 12:24 AM
xcaliber81
xcaliber81's Avatar
sounds funky it still works though. To use the rear washer fluid push the right stalk forward.
Valeo is the oem manufacturer for the rear wiper motor btw.
xcaliber81 is online now
post #4 of 32 Old 09-12-2020, 02:05 PM Thread Starter
HarveyCat
HarveyCat's Avatar
The whole thing is one piece right? Will a 1999 fit a 2003?
post #5 of 32 Old 09-12-2020, 03:31 PM
Falkon
Falkon's Avatar
Falkon is offline
post #6 of 32 Old 09-12-2020, 04:12 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Thanks. What about the rear window washer pump?
post #7 of 32 Old 09-13-2020, 02:11 AM
62JEEP
62JEEP's Avatar
2003 WJ
Replace the motor
That sounds familiar! I replaced my rear wiper motor to fix that same sound about 6 months ago. Everything's working OK again. Keep the old plastic molding that sits around the wiper motor stem. I had to reuse the old molding because the new one didn't match the profile of the exterior. The job took no more than a couple of hours.
Make sure you pick up some new Panel clips to replace the ones that are likely going to snap when you ease off the rear plastic panel. I bought these https://www.amazon.com/Lantee-Pieces...9984369&sr=8-4 off Amazon but I'm guessing you can get them in your local auto store.
Good luck.
62JEEP is offline
post #8 of 32 Old 09-13-2020, 08:11 AM
Falkon
Falkon's Avatar
Should be up front on the washer reservoir.
Falkon is offline
post #9 of 32 Old 09-13-2020, 10:38 AM
blueseasons
I have 2 WJ's and both mine sound just like that. I thought it was normal.
blueseasons is offline
post #10 of 32 Old 09-13-2020, 01:38 PM Thread Starter
HarveyCat
HarveyCat's Avatar
So if my front windshield sprays but my rear doesn't - then it is a hose or nozzle issue?
post #11 of 32 Old 09-13-2020, 01:39 PM Thread Starter
HarveyCat
HarveyCat's Avatar
Really - haha So I should just say it's a WJ thing.
post #12 of 32 Old 09-13-2020, 02:09 PM
Falkon
Falkon's Avatar
Could be. I'm really not totally sure, but believe there are 2 little pumps on the reservoir.
Falkon is offline
post #13 of 32 Old 09-13-2020, 02:12 PM
Falkon
Falkon's Avatar
Here you go.
Falkon is offline
post #14 of 32 Old 09-13-2020, 02:58 PM
Bigrigr
Bigrigr's Avatar
I believe there are two separate washer pumps. One for the front, and one for the rear, but they are both up front on the same reservoir inside the LF wheel well.
Bigrigr is offline
post #15 of 32 Old 09-13-2020, 06:54 PM
Golden-Arm
Golden-Arm's Avatar
open the hood, turn the key on, but dont start it. lean forward as far as you can, between the door and the door frame. push the washer stalk and listen for the pump. if it runs, you'll hear it. if you hear nothing, squirt the front one, just so you'll know what you're listening for. if the back pump runs, look for a leak, or a clogged nozzle.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
