What did you do to your WJ today? - Page 3397 - JeepForum.com
 4579Likes
post #50941 of 50969 Old 10-02-2021, 11:05 PM
IGoTmInE818
IGoTmInE818's Avatar
Bought her and she is already giving me staling problem, PCM?
04442781-E571-4275-83BE-5C4DDF8EB553.jpg   A325E286-839E-44F3-8BDF-D9E09EC61D67.jpg   8A8C988A-EB38-42FA-B3E6-1F8973EEBC8A.jpg   6C6962D0-6DD5-4085-B565-BF4E65B63099.jpg
2000 WJ 4.7L 4x4 Limited
Just Enough Essenial Parts
OIIIIIIIIO
IGoTmInE818 is offline
post #50942 of 50969 Old 10-03-2021, 07:51 PM
keith20mm
All parts transferred from old block to new, Promar, reman.
Before I put this in, I will replace upper control arms/bushings, replace heater hoses/flush heater core.
Since I will be installing transmission and engine, both, I would like to know, do any of you have a video of installing the two chunks, mated together, in one fell-swoop?
My condenser is still connected, in the typical, slanted, pose.
Is it possible, or am I hallucinating/delusional/suffering visions of grandeur, or, is it really possible? I have HFT cherry picker, leveler, many floor jacks, bottle jacks, block, etc.
2000 WJ 4.7 2WD 300000+ mi, 2nd engine/trans
2000 WJ 4.7 4WD 258777 mi, 2nd engine
keith20mm is offline
post #50943 of 50969 Old 10-04-2021, 07:38 AM
Soem0
Soem0's Avatar
Well when I put my new engine in I installed it with the engine trans and t-case all in one. However I didn't have to deal with my cond. I had a friend help and it was pretty easy with a HF picker
Soem0 is offline
post #50944 of 50969 Old 10-05-2021, 09:06 PM
WJ60
WJ60's Avatar
Nothing big. Thought these would look good.
99sajeep, electricd and mak_v8 like this.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #50945 of 50969 Old 10-06-2021, 12:45 PM
Mr. Bitey
Mr. Bitey's Avatar
I abused my WJ today. When they go through the effort to have a sign made, a guy kinda feels obligated. So I obliged the locals, then promptly went and bought 2 new tires.....
electricd likes this.
2004 WJ, 4.7 N, daily driver.
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (in progress)
1974 AMC Gremlin X, 440 6bbl (trailer queen, 9.466et @ 144mph)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #50946 of 50969 Old 10-07-2021, 08:33 AM
AdmiralSavage
AdmiralSavage's Avatar
I removed the front driveshaft due to hearing a popping noise at slow rolls and a grinding noise in 4x4.
AdmiralSavage is offline
post #50947 of 50969 Old 10-07-2021, 01:06 PM
cDee63
cDee63's Avatar
Finally found the creek in the rear suspension, upper spring isolator was worn through. Spring was rubbing on the cup in just a tiny spot.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is online now
post #50948 of 50969 Old 10-08-2021, 04:14 AM
mak_v8
mak_v8's Avatar
Finally changed the rear axle seal and pressed bearing and retainer!
Next step assembling everything.
Can't wait driving again my WJ!!
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #50949 of 50969 Old 10-08-2021, 11:17 AM
Brallen86
Brallen86's Avatar
2003 WJ
I just put my engine and trans back in mine last weekend as an assembly. Some things to note though;
  • My front crossmember is cut out for the TF front bumper, which makes it much easier
  • I didn't attach the tcase as it looked like it was gonna cause hangup issues
  • I did not have the AC or alternator attached
  • Initially I had the 08 intake mounted then I stuffed it in, was VERY tight, would've been much easier had I left it off for the install
  • I mounted the motor mount brackets (The "L" brackets that bolt to the frame) to the engine block mounts and left them semi tight so I could position them
  • 3 ratchet straps were used to aid in positioning, 2 on the sides and the 3rd went to the trans cable mount on the rear of trans for tilting it
  • I then shoved the engine into position, gently lowered it down while pushing it back until I could get the rear upper bolts (the ones that are slotted) started on the engine "L" brackets and buttoned up from there.
  • From there you can losen up the engine and tranny mounts to make it easier to install the tcase if you left it off
P.S. if you removed the transmission lines from the unit, put them back on before you stuff it in. They suck to re-attach under the jeep.
PXL_20211003_185124689.jpg   PXL_20211003_193606813.MP.jpg   PXL_20211003_193615927.jpg
cDee63, WJ60 and Mr. Bitey like this.
-03 WJ Limited; Check out my
Brallen86 is offline
post #50950 of 50969 Old 10-08-2021, 12:04 PM
Soem0
Soem0's Avatar
Honestly it wasn't bad with the tcase attached and my jeep has the cross member and is stock height. I didn't have my condenser in since the previous owner breached the system and it was empty.
Soem0 is offline
post #50951 of 50969 Old 10-08-2021, 02:43 PM
Brallen86
Brallen86's Avatar
2003 WJ
Ha, sure wish I tried putting it in with my tcase on. Definitely dropped the damn thing on my hand at least once while mating it up afterwards
post #50952 of 50969 Old 10-13-2021, 08:32 PM
cDee63
cDee63's Avatar
Removed this crusty rusty barnacle from the bottom of my transmission and replaced it with a pan.
99sajeep and WJ60 like this.
post #50953 of 50969 Old 10-15-2021, 03:00 PM
11B-33T
11B-33T's Avatar
2016 WK
Finished mucho maintenance on the WJ as I have to give to her to my daughter who's in need of a reliable DD.
Changed out power steering, brake, oil, coolant and transmission fluids. New battery, copper spark plugs, brake pads, wiper blades, engine air filter, rotated tires and replaced the original Goodyear Wrangler ST spare tire. That tires manufacture date was 0104
Just want to say many thanks to every-damn-body I've 'met', traded information and war stories with, as well as every bit of knowledge y'all have shared to help keep our WJs going.
I've already scored a replacement 2016 WK2 JGC Limited and have been reading up on this newer Jeep platform with all these danged bells, whistles and lights. I'll be hanging out more in the WK2 threads learning the ropes.
99sajeep likes this.
11B-33T
- 2016 WK2 Grand Cherokee Limited
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
11B-33T is offline
post #50954 of 50969 Old 10-16-2021, 02:23 AM
mak_v8
mak_v8's Avatar
Passed the biennal inspection, Jeep performs like new! (....more or less )
cDee63 and WJ60 like this.
mak_v8 is offline
post #50955 of 50969 Old 10-16-2021, 09:20 AM
cDee63
cDee63's Avatar
After the trans pan replacement I went through it the suspension tuning it in. That's the thing with adjustable arms, endless dialing in capability is a double edge sword to a retired suspension designer with OCD.
wj
Died today... jimbo141 WJ Grand Cherokee Forum 30 04-10-2020 11:22 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 46 04-02-2020 12:24 PM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
