What did you do to your WJ today? - Page 3389 - JeepForum.com
 4543Likes
post #50821 of 50928 Old 07-26-2021, 05:21 PM
GOLDWING
GOLDWING's Avatar
I am usually on the ZJ forum, but I have this in 54701 if anyone wants a sweet parts rig.
I will put it up in the classifieds also.
https://eauclaire.craigslist.org/pts...356761132.html
HassZJ1998 likes this.
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #50822 of 50928 Old 07-28-2021, 08:42 AM
xcaliber81
xcaliber81's Avatar
New battery fixed my slow crank shame it lasted only 3 years thanks to bad grounds.
xcaliber81 is online now
post #50823 of 50928 Old 07-28-2021, 07:24 PM
retrvrtrainer
retrvrtrainer's Avatar
Today I just did nit-noid stuff. Put Seafoam in the intake and dose appropriate Techron in the gas. I had a long drive today and she did great. Runs strong. I think I finally got her right...until the next thing anyway.
Matt 7:7-11
retrvrtrainer is offline
post #50824 of 50928 Old 07-29-2021, 04:03 AM
leadsled jeep
leadsled jeep's Avatar
Man I’d come by and snatch that up if you were close by. Sadly I am in TN.
'02 HO 235k ml. BDS, tubular arms, Addco sways. 245-70-17. Amsoil. W1CCW WRKi761
leadsled jeep is offline
post #50825 of 50928 Old 07-29-2021, 05:26 PM
Golden-Arm
Golden-Arm's Avatar
Originally Posted by cDee63 View Post
^^Nice plate, thanks for your service. USAF 81-85
thanks to you too, brother. i got 64, one-way trips from you guys. (i never trusted the air force guys enough to risk landing with them, so i took my chances and just jumped out in mid-flight, each time i got a lift. ) i'll be waiting to see your camera write up. i am considering a completely wireless one for the wk. the camera has a solar panel on it, as does the mirror, so they charge themselves and are totally wireless, in all respects
cDee63 likes this.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #50826 of 50928 Old 07-29-2021, 07:55 PM
cDee63
cDee63's Avatar
I didn't trust them either, lol. Flightline rat, F-16 Comm Nav ECM Specialist. Could not see well enough to fly them so I figured I'd do the next best and wrench on them.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #50827 of 50928 Old 07-29-2021, 08:12 PM
WJ60
WJ60's Avatar
I went out to move the Jeep to get my C10 out for a cardboard dump run. I pulled the cover I keep on it and low and behold, the right rear window is down. My first thought is I must have left it down and it's a good thing I had the cover on it due to a recent rain storm. Pushed the "up" switch and nothing. Ya got to love WJ's. This was a regulator assembly I picked up at the You Pull It yard almost exactly 2 years ago. The cable got bound up in the spool and broke the upper attachment. Have one coming from A1 Auto Parts.
WJ60 is offline
post #50828 of 50928 Old 08-01-2021, 02:24 PM
anarky321
ive replaced 3 of them and its always the passenger rear.....not sure why
2004 WJ 4.0L Freedom 4wd (daily)
2002 WJ 4.0L Laredo 2wd (backup)
anarky321 is offline
post #50829 of 50928 Old 08-04-2021, 05:36 PM
Mattyjm
Mattyjm's Avatar
It's because that one's being slammed shut more often than the others. Usually by kids who aren't told the right force with which to close the door.
2004 Special Edition WJ. LOADED!
Mattyjm is offline
post #50830 of 50928 Old 08-05-2021, 07:03 PM
WJ60
WJ60's Avatar
Received the window regulator from 1A today so spent about 30 minutes getting it in. New ones in all 4 doors now.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #50831 of 50928 Old 08-07-2021, 08:42 AM
H4ttorihanzo
I put my WJ on a flatbed headed to the salvage yard; but not before I pulled some saleable items:
Addco/IRO/Detroit Axle/Crown https://www.jeepforum.com/forum/show....php?t=4438839
H4ttorihanzo is offline
post #50832 of 50928 Old 08-07-2021, 08:47 AM
cDee63
cDee63's Avatar
Got a slight misfire on start up this morning, CEL #7 misfire detected. The crap part is I also smelled coolant, a plug pull confirmed it. !&^%&$!!!
cDee63 is offline
post #50833 of 50928 Old 08-07-2021, 01:54 PM
WJ60
WJ60's Avatar
Replaced the right rear axle bearing, bearing retainer, and seal. Installed a new rotor. Cleaning up the old rotors to use as back ups. I didn't care for the rust showing through the wheel so I went with the Wagner rotors that have a black coating. Replaced the PCV also.
WJ60 is offline
post #50834 of 50928 Old 08-08-2021, 11:59 AM
GmanWJ
GmanWJ's Avatar
That disconnect knob you have on your negative terminal ... First time I saw one of those things I thought YES I NEED ONE. Then my neighbor the retired AF Chief asked me for some help one day because his Lincoln would not start and he always sees me out there working on the Jeep, maybe I can figure it out. So I take a look under the hood and he has one of those disconnects on the battery. Ask him to turn the key ... Nothing happens. No cabin lights. No power. I touch the disconnect, do not turn it, simply touch it, then stop and go get my DMM. Battery shows 12V on both sides of the disconnect. Tell him to try it again: started right up. Now I do not trust those disconnects at all.
As always, your results may vary, but I would ditch the disconnect if you are having ground troubles.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #50835 of 50928 Old 08-08-2021, 12:36 PM
xcaliber81
xcaliber81's Avatar
Honestly I don't think I do? I did have ground issues before I cleaned up my grounds. There was a few times my battery died because if that and once I cleaned the grounds up I was able to hold a charge longer so I believe my battery was weak due to that. Seems good so far but I wont rule it out.
Going to put my exhaust ground straps on today and clean the power side of the alternator and the starter leads as well.
Also someone left the ground strap off the drivers rear of the coil I am sure that didn't help matters.
wj
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
volvite
Died today... jimbo141 WJ Grand Cherokee Forum 30 04-10-2020 11:22 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 46 04-02-2020 12:24 PM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
