What did you do to your WJ today? - Page 3372 - JeepForum.com
 4370Likes
post #50566 of 50735 Old 05-06-2021, 06:30 PM
Golden-Arm
Golden-Arm's Avatar
Originally Posted by WJ60 View Post
At least the cabin filter will be easy.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #50567 of 50735 Old 05-06-2021, 06:34 PM
WJ60
WJ60's Avatar
WJ60 is offline
post #50568 of 50735 Old 05-06-2021, 06:40 PM
Golden-Arm
Golden-Arm's Avatar
Originally Posted by cDee63 View Post
I have a homemade spacer under my also junk crown upper, though it was the side bushings that went south on mine in less than 2 years. I will be initially running 3", I'll run without the homemade one for now, see what happens.
nothing wrong with homemade. i got a deal on my goliath, as a "blem". i see nothing wrong with it, and it's a hidden part anyways, so score for me! i run off--road at work, basically like running fire-roads or trails through the swamps, and i run them at regular road speeds. it's hell on the suspension running at 40 mph down the right-of-way, so i understand why my crown stuff failed, but it should have lasted a year at least, right? i run the wj like i'm chasing rod hall down the baja, so i take a tiny bit of responsibility for the rapidly failing suspension parts.
GTP231 likes this.
post #50569 of 50735 Old 05-06-2021, 10:20 PM
WJ60
WJ60's Avatar
Had to cover it because I haven't heard when the solenoid block is arriving. Don't need the pine tree dripping pitch all over it.
HassZJ1998 likes this.
WJ60 is offline
post #50570 of 50735 Old 05-07-2021, 09:04 AM
xcaliber81
xcaliber81's Avatar
I made a new friend last night. And his distant cousin the air ratchet lol
xcaliber81 is offline
post #50571 of 50735 Old 05-07-2021, 03:02 PM
underscore
I got the front tcase seal free, and the new one in. After doing that one and the pinion seal I officially hate these kinds of seals so hopefully I don't have to do any more. I got the new tcase yoke back on too, this time without the old spline gasket still on it (oops) so hopefully it won't leak any more.
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #50572 of 50735 Old 05-08-2021, 07:48 AM
cDee63
cDee63's Avatar
Ordered up the rest of the parts for the lift from Kolak. IRO 3" front long arm lift with a full set of Bilsteins to go with the IRO upper and adjustable lowers for the rear I picked up a while ago. Great price AND he tossed in a bonus item, thanks!
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include IRO SYE and Woods DS
2006 Crown Vic Interceptor SOLD
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #50573 of 50735 Old 05-08-2021, 08:24 AM
Golden-Arm
Golden-Arm's Avatar
talked to alex at iro he says the spacer is not needed, with the new adjustable a-arm with the ball/trunion joints on it. so, i guess i'm gonna put it into the box with all the other extra stuff i didn't really need, but somehow ended up with anyways.
cDee63 likes this.
post #50574 of 50735 Old 05-08-2021, 02:01 PM
GTP231
1992 XJ Cherokee
Dragged something home
92 Cherokee Laredo
04 Grand Cherokee Special Edition
6 in a row they kind of go
GTP231 is offline
post #50575 of 50735 Old 05-08-2021, 05:02 PM
WJ60
WJ60's Avatar
Are you running a class 4 towing package in the Special Edition? What does the trailer weigh loaded? How did it handle towing the trailer?
WJ60 is offline
post #50576 of 50735 Old 05-08-2021, 05:38 PM
Golden-Arm
Golden-Arm's Avatar
finished the rear end work. new upper and lower control arms, new shocks, new swaybar, and bushings. new end links, new brakes, rotors, calipers. still have that mf'ing rattle. i'm gonna do the charcoal canister bracket behind the rear bumper fascia. the only thing it can be, after that, is the rear liftgate. the wander it had developed over the past couple of months is gone though.
post #50577 of 50735 Old 05-08-2021, 08:49 PM
AZdEvilYJ
AZdEvilYJ's Avatar
I think these guys were a little corroded. Placed an order with Jeepcables.com for an upgrade. The ground side clamp is almost completely gone
Sent from my iPhone using Tapatalk
'95 YJ 2.5L
March '19 YJ of the Month!
My Build Thread
Do your best and caulk the rest
-Albert Einstein
AZdEvilYJ is offline
post #50578 of 50735 Old 05-09-2021, 03:16 AM
Doodlestang
Thumbs up
I just finished their cable instal on my 04 overland. Great quality kit. Iíve had the Jeep for 7 years and 2 batteryís and a new starter and itís always been a slow cranked now it crank real fast very pleased.
Doodlestang is offline
post #50579 of 50735 Old 05-09-2021, 09:27 AM
GmanWJ
GmanWJ's Avatar
What is that cool little bellows thing you have attached to your axle breather port?
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #50580 of 50735 Old 05-09-2021, 09:45 AM
AZdEvilYJ
AZdEvilYJ's Avatar
Thatís great to hear! Was it pretty easy install? It didnít look like it came with Instructions
'95 YJ 2.5L
My Build Thread
-Albert Einstein
wj
Died today... jimbo141 WJ Grand Cherokee Forum 30 04-10-2020 11:22 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 46 04-02-2020 12:24 PM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
