What could be causing my exhaust to suck in intermittently - JeepForum.com
 1Likes
post #1 of 25 Old 07-20-2021, 05:41 PM Thread Starter
Rylxmp
2003 WJ
Hi, I have a jeep gc with the 4.7 HO and 180k miles on it. I was having a minor rough idle and decided to try a trick i saw which was placing a paper over the exhaust to see if it sucks back in. It says that this trick shows you if you are having valve issues but i dont know how credible it is. When i decided to try it out, the paper would get somewhat sucked towards the exhaust after every 10 to 15ish seconds. I dont have any other issues that would lead me to believe that its a burnt valve or leaking valve seal and my gas mileage is great with also no CEL coming on. I also stay on top of maintenance and have replaced mainly everything on its interval ever since owning the vehicle. My question is, what causes the paper to get somewhat pulled back inconsistently ? thanks
Rylxmp is offline
post #2 of 25 Old 07-21-2021, 06:37 AM
Delta0
It's an old trick used by unscrupulous garages to scam punters into valve jobs.
A compression test is the only reliable way I know to check the top end of your engine.
As the fat lady advised, if it ain't broke, don't fornicate it up.
Bigrigr likes this.
Delta0 is offline
post #3 of 25 Old 07-21-2021, 06:55 AM
CJREX
CJREX's Avatar
If it was truly an indicator of valvetrain issues, it would happen a LOT more often than every 10 to 15 seconds since the engine is performing 700-1000 full revolutions per minute at idle.
2004 GC Overland 4.7 HO
Powerful Wanderer (wife named it after driving it)
265/70/17 MT, 2" BDS lift
CJREX is offline
post #4 of 25 Old 07-21-2021, 06:56 AM
jtec
jtec's Avatar
2014 JK Wrangler
Agree if it ain;t broke don't F.. with it.
No cel? - Always SCAN, the cel can be inop* and there are codes that will not command the CEL on.
*the CEL should come on at every start for @2seconds then go out.
jtec is online now
post #5 of 25 Old 07-21-2021, 01:09 PM
Delta0
There is a possibility that interference between waves of exhaust coming down one pipe to the Y interferes with waves coming the other pipe to cause high and low pressure in the pipe after the union.
I recall looking down at an "arroyo" that ended just before the trough on which the catamaran in which I was on watch.
Infront, the wave towered some 35ft above us.
To my right there was the trough in which we sailed.
To my left, there was nothing until I looked down.
Happily, we went up the next wave, leaving the double trough behind.
Delta0 is offline
post #6 of 25 Old 07-21-2021, 04:52 PM
fracturedapple
Its a quick and dirty test to see if a car is misfiring only.
I've seen this put holes in paper and you will hear it.
Doesn't mean you have valve issues.
In your case maybe your mistaking the rebound of the paper from the exhaust pulse as the suck? Maybe a little windy? Not sure
As everyone is saying if you have no drive ability issues don't worry about it.
Sent from my SM-G965U using Tapatalk
fracturedapple is offline
post #7 of 25 Old 07-22-2021, 10:20 AM
Bigrigr
Bigrigr's Avatar
Throw the paper in the trash and add some fuel injector cleaner to the gas tank. You will be further ahead....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #8 of 25 Old 07-22-2021, 03:12 PM
Double E
Double E's Avatar
Agree that the paper thing is not a valid diagnostic tool.
You would be better off doing the maintenance items mentioned like a bottle of FI cleaner.
I would also swap out the TPS (super easy), clean the back of the throttle body and verify the battery connections are clean and tight.
Beyond that, swap spark plugs if you do not know when they were last done.
That you got to180K is super. You're paying attention to the fragile 4.7 HO. Keep it cool, change the oil regularly and you should easily get another 80K out of it before big and expensive stuff happens.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #9 of 25 Old 07-22-2021, 03:48 PM
2oldjeeps
2oldjeeps's Avatar
what on earth could cause vacuum in exhaust.
stuk ex valve during intake stroke.
anything else??
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #10 of 25 Old 07-22-2021, 04:00 PM
fracturedapple
Misfire means no power stroke no pressure no heat.
Instead you get decompression. When the piston reaches bottom Dead center the cylinder is in a vacuum.
Then exhaust valve opens while that cylinder is under vacuum. = vacuum in exhaust.
If your really curious john Thornton has some interesting videos about in cylinder pressure testing that have found their way to YouTube
post #11 of 25 Old 07-22-2021, 08:09 PM
2oldjeeps
2oldjeeps's Avatar
Instead you get decompression.....???why??
the cylinder is in a vacuum.?? why??
99wj, 150,000 miles
00xj ,189,000 miles
98xj, 133,000 miles
post #12 of 25 Old 07-22-2021, 09:55 PM
Boojo35
1987 YJ Wrangler
It is not a worthy test. Do not waste your time says the mechanic that is older that most T- rex's. We have compression tests, leakdown tests, timing tests, etc. Some paper over an exhaust???? Find it one time in a manual and then bring it back to how it is a legit test. This is the worst internet lore ever. What a joke.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #13 of 25 Old 07-23-2021, 12:48 AM
Delta0
Think about a wave pool.
In the beginning.
A little dubry at one end, lobs a little wave at a doofer at the other end.
The doofer lobs the little wave back ai the dubry.
Somewhere about the middle, the new wave from the dubry collides with the wave from the doofer forming a big wave, and a big trough.
Now transfer that picture to you exhaust.
Each pop in the engine sends a little wave down the front pipe into the silencer / muffler.
The back end of the silencer lobs the little wave back to meet the next little wave from a cylinder.
Every so often a big wave and a big trough form in the silencer.
The big wave pushes the paper away.
The big trough sucks the paper in.
It's the way the world goes round.
Delta0 is offline
post #14 of 25 Old 07-23-2021, 05:52 AM
CJREX
CJREX's Avatar
When the fuel/air mixture is pulled into the cylinder, the spark plug ignites it and it rapidly expands, pushing the piston down to create a power pulse.
If the mixture doesn't get ignited (misfire), it doesn't expand and the piston creates a vacuum as it moves down.
When the exhaust valve opens, air rushes in to fill the vacuum and the only source of air at that point is pulling it back through the exhaust system.
CJREX is offline
post #15 of 25 Old 07-23-2021, 07:12 AM
Delta0
what on earth could cause vacuum in exhaust. Have you ever watch the flapper valve on vertical exhaust pipe 2Old?
anything else??
Delta0 is offline
