What is this and could it cause P0601!? - JeepForum.com
post #1 of 4 Old 07-16-2020, 08:27 AM Thread Starter
Frambo
Hey all
Got a CEL and p0601 code. Whilst that usually means a bad Ecu, I removed the battery and tray over the weekend and when I checked just now I found this mystery sensor / plug / fuse / loose in the engine bay. Any ideas what it is and where it should go? I have a road trip tomorrow so would like to set off with peace of mind!
EDIT: I have since found out that this is the brake fluid level sensor and plugged it back in. Regarding the p0601, I appreciate that it seems to occur randomly but over the weekend I did accidentally reconnect my battery without reconnecting the ground pin on the fuse box. Could that be behind it? Seems doubtful though as the CEL and code only appeared today
It's on British driver's side if that helps
Cheers!
Frambo is offline
post #2 of 4 Old 07-16-2020, 08:50 AM
jtec
jtec's Avatar
2014 JK Wrangler
thoughts:
what are the wire colours?
Give an idea the length of wire - it would reach air Intake, eng manifold, coolant bottle, etc?
Read codes (scanner) unplug sensor see if another code appears...
jtec is offline
post #3 of 4 Old 07-16-2020, 11:31 AM Thread Starter
Frambo
Originally Posted by jtec View Post
thoughts:
Figured out it's the brake fluid level sensor but that doesn't explain the P0601!
Frambo is offline
post #4 of 4 Old 07-16-2020, 01:35 PM
jtec
jtec's Avatar
2014 JK Wrangler
p0601 is an internal PCM issue.
jtec is offline
