What 16" Steel Rims Fit? - JeepForum.com
 2Likes
  • 1 Post By cDee63
  • 1 Post By mdwildcat04
post #1 of 10 Old 05-06-2021, 06:28 PM Thread Starter
Wabatuckian
Wabatuckian's Avatar
Hello,
I have always disliked aluminum rims. I'm looking for some 16" steel rims to swap onto my WJ. Where should I look? This is a new bolt pattern over the ZJ, isn't it?
Thanks.
Josh
Wabatuckian is offline
post #2 of 10 Old 05-06-2021, 06:32 PM
xcaliber81
xcaliber81's Avatar
Dodge journey wheels are the same at least for the 17" steelies according to Canadian tire.
xcaliber81 is offline
post #3 of 10 Old 05-06-2021, 07:14 PM
cDee63
cDee63's Avatar
16" JK steelies will fit, I run my winter tires on them.
Wabatuckian likes this.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include IRO SYE and Woods DS
2006 Crown Vic Interceptor SOLD
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #4 of 10 Old 05-06-2021, 10:06 PM
GmanWJ
GmanWJ's Avatar
It's a 5x5 bolt pattern (aka 5-on-5). Oem backspace 6.5 inch on a 16" rim will clear the tie rods. That's a lot of backspace, most of the wheels I have looked at are 5.5 or less, so basically any 16" or 17" rim will fit. On 15" rims you have to worry about tie rod clearance so you must be more careful about backspace; make sure you have room. But I cannot tell you what max backspace is on 15". Somebody here knows, though.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #5 of 10 Old 05-06-2021, 11:01 PM
underscore
The newer (I want to say 08+?) Town and Country is the same bolt pattern and hub bore as well. WK's and JK's have the same pattern but other than some very early 05's all WK's only fit 17's.
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is online now
post #6 of 10 Old 05-09-2021, 10:36 AM
mdwildcat04
I am running Unique 297 wheels, a copy of the classic Cragar soft 8 wheel. 16x7 with 0 offset. they stick out more then stock, but works with my setup.
IIRC, most 16" wheels with 5x5 bolt pattern should fit. 15" are hit or miss, more miss then hit. Having the (worse) Teves calipers give you more room then the Akebono calipers
mdwildcat04 is offline
post #7 of 10 Old 05-10-2021, 02:43 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'm curious, why the dislike for alloy wheels?
Wheelin98TJ is offline
post #8 of 10 Old 05-10-2021, 03:22 PM
mdwildcat04
I won't speak for the OP, but for me, offroad survivability. Alloy is stronger, but alloy breaks when steel bends. You can still drive on a bent wheel, not a broken one.
WJeepster likes this.
post #9 of 10 Old 05-12-2021, 10:04 PM
GTP231
1992 XJ Cherokee
08 and up minivans do not have a 5x5 bolt pattern
92 Cherokee Laredo
04 Grand Cherokee Special Edition
6 in a row they kind of go
GTP231 is offline
post #10 of 10 Old 05-12-2021, 10:51 PM
underscore
Yes they do, I put them on my WK.
https://wheelssize.com/wheels/chrysler/town-country/
00 WJ
