Weird howl I can't figure out - JeepForum.com
post #1 of 10 Old 11-26-2019, 10:27 AM Thread Starter
smokeyyank
So the jeep has developed a random howl/hmmm between 30-40 mphs. It doesn't always happen and I can't track it down. It is on the passenger side that's about as far as I got.
Here's what I've done so far in trying to figure our WTF is going on
-It's not speed dependent so it sounds the same regardless regardless of 30 or 40.
-It's not dependent on RPMs, so I can punch it doesn't change the pitch. Doesn't matter if I'm coasting or on the gas.
-It's not related to brakes, I can tap and slam the breaks and doesn't change anything.
-Once it goes above 40 sounds disappears.
I do think it could possibly be a pump of sorts only because when I get around 28-29 MPH it sounds like a pump is trying to keep up. But I have no idea what "pump".
Any ideas?
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is online now
post #2 of 10 Old 11-26-2019, 10:40 AM
JGCJeep
In neutral?
JGCJeep is offline
post #3 of 10 Old 11-27-2019, 05:11 PM
GmanWJ
GmanWJ's Avatar
Could it possibly be your tires? They can make speed dependent noise of varying pitch which can come and go, may even have beats in it, may sound different when going around corners vs straight lines. My old BFGs were making so much noise that I couldn't be sure whether I also had multiple bearings whining or not. Everything is much quieter now with a new set of Falkens.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #4 of 10 Old 11-27-2019, 09:27 PM
2yellow69
2yellow69's Avatar
Is it loud? Like, roll down the window and you can hear it echo off the curb or a fence? Embarrassing until you drop below about 15 mph? Mine was more of a howl/screech. It started after I did the front unit bearings but only when it was cold outside. Had me stumped for a long time. Re torqued the front unit bearings and it went away.
Matt
2yellow69 is offline
post #5 of 10 Old 11-27-2019, 10:26 PM Thread Starter
smokeyyank
Not a tire howl. Tires are newer and never had any issues. Bearings are a possibilty but it doesnt make sense that the sounds doesnt change with speed and the start of the sound doesnt indicate anything driveline. The start will kind of be a puttering sound. Hasn't made the sound recently so haven't been able to try the neutral trick.
04 WJ, 4.7HO
post #6 of 10 Old 11-28-2019, 08:01 AM
LelandGray
My WJ has a similar sound, starts right around 35mph and goes away the faster I go. The weird part about my noise that it comes when my foot is on the gas and goes away as soon as I take my foot off the gas. And it doesn't really change in pitch, just gets louder and quieter. I haven't really had a chance to look at it yet.
2001 WJ Limited w/ QuadraDrive
Bilstein 5125's
jgcparts 2.5"/2" BB
JK take offs & 265/75R17's
LelandGray is offline
post #7 of 10 Old 11-28-2019, 09:45 PM
86cj74.2L
86cj74.2L's Avatar
Does it happen cold only or anytime.
V8 or I6?
Sent from my iPhone using Tapatalk
86cj74.2L is offline
post #8 of 10 Old 11-29-2019, 12:23 AM
new2site
Plastic wheel well broke partially loose?-- it's just on there with about 8 plastic clips..... now exposed to wind?
new2site is offline
post #9 of 10 Old 11-29-2019, 09:59 AM Thread Starter
smokeyyank
It just started and its been cold but again some days it does it other not. Wheel well I could check out. The passenger side has been a little floppy and otten cut up from driving. Could have a spot that creates a whistle.
04 WJ, 4.7HO
post #10 of 10 Old 11-30-2019, 06:10 AM
86cj74.2L
86cj74.2L's Avatar
I herd about the intake manifold cracking causing it.
