Weird coolant leak location - JeepForum.com
 1Likes
  • 1 Post By Freedom2004jeep
post #1 of 11 Old 09-26-2020, 04:56 PM Thread Starter
Freedom2004jeep
Just slapped a used 4.0 in my WJ today filled her up with fluids and of course I see coolant coming out the bottom. Ok ok I must have forgot to put something on. Nope, it’s dripping out from what looks like the front of the oil pan right over the top of the gasket. Front of the block looks fine I’m not seeing coolant by the water pump or the stat housing. Wtf am I missing before I shoot this truck and drive it off a cliff. I am so tired of taking this thing apart it sucks to be poor. Lol
Nothing says freedom like a Jeep and an open trail.
Freedom2004jeep is offline
post #2 of 11 Old 09-26-2020, 06:21 PM
WJ60
WJ60's Avatar
Did you happen to take any pictures?
WJ60 is online now
post #3 of 11 Old 09-26-2020, 09:07 PM Thread Starter
Freedom2004jeep
I’ll take a vid in the morning and post it up or at least pics. Just makes no sense it’s coming from there
WJ60 likes this.
post #4 of 11 Old 09-27-2020, 09:12 AM Thread Starter
Freedom2004jeep
You can see it dripping from what appears to be right over the oil pan gasket
post #5 of 11 Old 09-27-2020, 09:40 AM
anotherheep
Did it start dripping right after the repair before you drove it much? Maybe a dumb question, but are you sure it isn't coming from somewhere else and getting blown onto where it looks like its dripping from?
anotherheep is offline
post #6 of 11 Old 09-27-2020, 09:48 AM
anotherheep
I'd clean the whole front area of the motor off with brake clean and hit it all with an air gun to get it good and dry, then fire the motor up and watch it again.
post #7 of 11 Old 09-27-2020, 03:17 PM
Bigrigr
Bigrigr's Avatar
Is there water in the oil? Seems like there should be if its coming out of that seam...But i would make dang sure its not coming from the water pump or higher if it were me...theromostat housing maybe?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #8 of 11 Old 09-28-2020, 07:21 AM
Valentine1
Valentine1's Avatar
might be dripping down from the water pump housing making it look like it's coming from the front main area
'04 WJ Special Edition 4.0 w/ 42re. Kumho AT-51's
Valentine1 is offline
post #9 of 11 Old 09-28-2020, 10:20 AM
GmanWJ
GmanWJ's Avatar
That coolant has to be coming from somewhere besides the oil pan gasket. If it is not the thermostat, water pump, or heater hoses, maybe it is the timing chain cover? I think mine is seeping a bit.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #10 of 11 Old 09-30-2020, 11:33 PM
thumperjohn151
thumperjohn151's Avatar
1987 FSJ Wagoneer
From the "weep" hole? Under the water pump? Hard to tell -
What they said to do - clean it up, dry it off with air, bright light, watch it....
thumperjohn151 is online now
post #11 of 11 Old 10-07-2020, 05:45 PM
brandon2866
just happened to get the same leak today, did you figure out your cause?
brandon2866 is offline
