weak varilok operation - JeepForum.com
post #1 of 7 Old 04-15-2019, 07:16 AM Thread Starter
97jeepxj1
I've noticed that while my rear varilok seems to work awesome when tested (rear in the air spin one tire other goes other way for a second then stiffens up to where i can barely turn) my front end on the other hand seems pretty weak in comparison. It still works but instead of the opposite tire changing direction it just kind of stops and hangs out. It will try to turn it but really it just kind of rocks a little bit. Guess i could make a video to better explain. Anyways like i said the front isn't nearly as stiff or strong. I did change fluid in both ends and added 2.5 oz of the modifier in the front anbd 4 in the rear when i got it back in june. I checked the fluid level and it was still good so it doesn't appear to be leaking. I however can't remember now if the oil i used had the premix in it for LS diffs but would think if it did it would have affected the rear also.
97jeepxj1 is offline
post #2 of 7 Old 04-15-2019, 09:26 AM
LuthWJ77
LuthWJ77's Avatar
what about in an actual driving condition? can you get it on something slippery and see if it grabs then? Maybe needs more revolutions to build enough pressure? Try changing fluids again or could be that thingamabob that makes the vari lok work is going out. My understanding is there is no rebuild kits for those unfortunately.
LuthWJ77 is offline
post #3 of 7 Old 04-15-2019, 09:52 AM
Photoweborama
Photoweborama's Avatar
Well I donít know much, but I do know the rear is a 40 series and the front is a 30. Itís a lighter axle so itís going to react different.
I love Quadra Drive and use it over 4WD most of the time.
Only driving tests will tell.
Sent from my iPad using Tapatalk
Photoweborama is offline
post #4 of 7 Old 04-15-2019, 10:28 AM
Uniblurb
Uniblurb's Avatar
You likely have the same quadra-drive like I do in my 04 4.7 with vari-lok axles and 247 transfer case. If you changed the axle fluids and added the correct amount of friction modifier isn't it also time to change out the 247 TC fluid while adding new? You may be able to find the special 247 Mopar fluid cheaper than below and you'll need to buy 2 quarts. Mine took about 1.75-1.8 qts.
https://www.amazon.com/Genuine-Chrys...s%2C173&sr=8-6
I've been chasing some binding on my quadra-drive system and while it was still there after changing my D30 and D44a axles it seemed to get a whole lot better in just changing my 247 TC fluid.
While these fluid changes are my 30K mile maintenance there's a real good video out there by Martin on changing the TC fluid. Know it isn't difficult but one thing I picked up on his video is he said the TC fluid for the 247 may be needed changed at 20K miles rather than 30K miles since the friction modifier may break down in the fluid quicker than thought.
I'm not sure how good that test you're doing is in just spinning the wheels by hand and it needs to be driven on a slick service to test as already mentioned. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #5 of 7 Old 04-15-2019, 12:42 PM Thread Starter
97jeepxj1
My wj is like yours its and 04 overland and i did actually swap the tcase fluid also when i did the axles back in june. I just got back from the salvage yard with my 242hd case i am going to swap in for more options.
I can get the front end to catch on a slick surface but still don't think the varilok works right. Granted its my first varilok so who knows
post #6 of 7 Old 04-15-2019, 12:57 PM
HarryH3
Assuming that your Jeep is QuadraDrive, with the stock NP-247 transfer case, did you have the transmission in park during your testing? If so, the results will be different between front and rear because in the rear the driveshaft is locked in place, while in 4 Hi the front driveshaft is not. To compare both ends, you need to test with the trans in neutral or with the t-case in 4 Lo.
HarryH3 is offline
post #7 of 7 Old 04-16-2019, 12:13 AM Thread Starter
97jeepxj1
Believe I had the case and trans in neutral.
Question on 2019 JGC Heater Operation yamon WK2 Grand Cherokee Forum 3 02-28-2019 07:43 AM
Varilok or trutrac weaselsmopar WJ Grand Cherokee Forum 14 10-21-2018 01:07 PM
03 WJ Weak Turnover? deoxys987 WJ Grand Cherokee Forum 11 09-04-2018 09:49 AM
WJ with Weak Passenger Side Air jepsenkc WJ Grand Cherokee Forum 12 08-14-2018 01:26 PM
WJ 2004 Laredo A/C blower weak airflow HassZJ1998 WJ Grand Cherokee Forum 27 05-21-2018 04:59 AM
