water in oil - JeepForum.com
post #1 of 5 Old 08-13-2019, 02:17 PM Thread Starter
natoriusbob
water in oil
Hi all this is the first time posting here. I have a 04 with the 4.7 h.o. engine. It stated over heating last year so its been sitting. So far I put a new radiator in it a thermostat. Still had issues. At first I didn't have water in the oil. Then it started blowing out white smoke checked the oil now there is water in the oil. My first thought was head gaskets. So I checked the compression. It was 120 to 136 psi across all 8 cylinders so I don't see how it could be that. So I was wondering if it could be coming in through the timing chain cover. Has anybody else had this problem before. Any help would be appreciated. Especially before I start tearing it apart.
natoriusbob is offline
post #2 of 5 Old 08-13-2019, 05:29 PM
sdg3205
sdg3205's Avatar
If you're blowing white smoke, it's in the combustion chamber. Pull your plugs, pressurize the system to 21 psi and use a bore scope to look for the leak.
sdg3205 is offline
post #3 of 5 Old 08-14-2019, 03:42 PM
Mattyjm
Mattyjm's Avatar
I bet you find that it's a cracked head and not a blown headgasket.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #4 of 5 Old 08-15-2019, 10:47 AM
99wjtx
99wjtx's Avatar
As a last resort, try some of that mechanic-in-a-bottle coolant leak/head gasket seal stuff. It can work. I've had success with Rislone Liquid Copper Block Seal but there are other good products on the market too. It may even take two bottles. You could end up with some side effects like a partially clogged heater core but hey if it works, you can eventually drain it out with the coolant and refill. The fix is supposed to be essentially permanent (if it works).
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #5 of 5 Old 08-15-2019, 01:50 PM Thread Starter
natoriusbob
There was a lot of water in the pan when I drained it. I still think it maybe the gasket on the timing cover.
The water jackets are built into that. The water pump bolts to it.
Thanks for the reply.
