Warning for aftermarket pre-formed brake line set users - JeepForum.com
post #1 of 7 Old 06-13-2021, 05:36 PM Thread Starter
keith20mm
There is a set of pre-formed brake lines from inlinetube, and for the right front route, this route comes in 2 pieces, for some inexplicable reason. The junction of the 2 pieces is right along about even with the starter location on a 4.8L left driver vehicle.
This junction is not part of the OEM brake line 52128366AB.
So if you happen to plan on using this particular aftermarket pre-formed brake line set, from inlinetube, then have on hand a pair of brake line couplers, one for mid-underbelly, and one for the right front splice.
I do not yet know the correct thread size for these male end pieces.
Hopefully, one of you will know, so TIA.
2000 WJ 4.7 2WD 300000+ mi, 2nd engine/trans
2000 WJ 4.7 4WD 258777 mi, 2nd engine
keith20mm is offline
post #2 of 7 Old 06-15-2021, 07:27 PM
Golden-Arm
Golden-Arm's Avatar
so, beware of this particular brake line set, (whose name you don't list) for a jeep with what appears to be a chevrolet engine in it? (4.8 is a chevrolet engine) okay, got it!
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #3 of 7 Old 06-15-2021, 07:36 PM
anotherheep
Lol Jeep, like a rock
anotherheep is offline
post #4 of 7 Old 06-15-2021, 07:40 PM
WJ60
WJ60's Avatar
I think the 4.8 was a mistake. The part number does correspond to a WJ with the 4.7.
WJ60 is offline
post #5 of 7 Old 06-15-2021, 07:48 PM
Golden-Arm
Golden-Arm's Avatar
i'd venture a guess, if the parts you got don't match the picture of what you need, you don't have the correct parts. if you have a parts diagram from your jeep (available online, for free viewing) and the picture of the part your getting, has significant differences, find another vendor (oem/nos is always a good bet, if your wallet allows)
post #6 of 7 Old 06-15-2021, 07:50 PM
anotherheep
Between yesterdays thread and this one, I wasn't sure what was going on
post #7 of 7 Old 06-15-2021, 08:41 PM Thread Starter
keith20mm
I believe I mentioned "inlinetube", and if you look over the footer, I have two 4.7L 2000 WJ.
ok?
