Vibration Noise over 60 mph - JeepForum.com
post #1 of 14 Old 06-13-2019, 05:30 AM Thread Starter
warrenyoda
I get what sounds like a vibration noise at speeds over 60 mph. New tires,balanced tires.
warrenyoda is offline
post #2 of 14 Old 06-13-2019, 07:37 AM
LuthWJ77
LuthWJ77's Avatar
You're hearing a vibration or you feel one? Tires can cause road noise depending on tread design or wear patters and also cause vibrations for the same reasons plus out of balance. Kind of hard to diagnose this kind of thing over a forum but a little more detail would help.
LuthWJ77 is offline
post #3 of 14 Old 06-13-2019, 11:04 AM Thread Starter
warrenyoda
I had new tires put on.
Had tires and wheels high speed balanced.
Same sound on different freeways.
It's not a feel it's a sound.
post #4 of 14 Old 06-13-2019, 11:23 AM
LuthWJ77
LuthWJ77's Avatar
If it's a new sound that started with new tires most likely it's the tires or maybe just one is defective somehow. Take it back and have them rotate the tires see if it moves or changes. Otherwise if it was there before too could be a lot of things.
LuthWJ77 is offline
post #5 of 14 Old 06-14-2019, 09:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
I agree with @LuthWJ77 . If the sound appeared with the tires, it's the tires. If not, it could be your driveshaft, wheel bearings, etc. Does the vibration change with speed?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #6 of 14 Old 06-15-2019, 12:26 PM Thread Starter
warrenyoda
Noise starts at 60mph. Slower speeds there is nothing.
post #7 of 14 Old 06-17-2019, 09:06 AM
LuthWJ77
LuthWJ77's Avatar
What I'd do next is check diff fluid level. If good take a look at driveshaft u joints. Those seem ok I'd probably pull diff covers make sure nothing is wrong there.
LuthWJ77 is offline
post #8 of 14 Old 06-17-2019, 09:54 AM
Barber613
I have had a stuck or frozen brake caliper cause an issue like this.
Barber613 is offline
post #9 of 14 Old 06-17-2019, 10:09 AM
LuthWJ77
LuthWJ77's Avatar
Yeah I'd be checking everything that's rotating. OP mentioned a noise / vibration in his first post was kind of leaning U joint but obviously it's tough to diagnose over a forum.
LuthWJ77 is offline
post #10 of 14 Old 06-18-2019, 11:23 AM Thread Starter
warrenyoda
What grade oil do I use in the differential ? Do I need any additive ? Its a 2004 Grand Cherokee Lerado WJ 4x4 6 cyl.
post #11 of 14 Old 06-18-2019, 11:29 AM Thread Starter
warrenyoda
what grade oil does it take?
2004 Grand Cherokee Laredo WJ 4x4 ^ cyl
post #12 of 14 Old 06-18-2019, 11:34 AM
LuthWJ77
LuthWJ77's Avatar
Here's a good source for answers to things like that. Additive depends on if you have limited slip or not.
http://wjjeeps.com/
LuthWJ77 is offline
post #13 of 14 Old 06-18-2019, 11:57 AM Thread Starter
warrenyoda
does not start till above 60mph.
post #14 of 14 Old 06-23-2019, 03:31 PM Thread Starter
warrenyoda
Replaced both front rotors,pads,calipers. Vibration still there.
Took it to a driveline shop. After a highway test drive,$14.76 for a new front driveshaft u joint. All fixed.
