Vari-Lok - Has anything changed? - JeepForum.com
 3Likes
  • 1 Post By cDee63
  • 1 Post By Sangster
  • 1 Post By cDee63
post #1 of 12 Old 10-05-2021, 03:24 PM Thread Starter
TheZombie
1993 XJ Cherokee
I've looked around here and Googled trying to find out if spider gears are available for D30 or 44 differentials yet. I see mostly old posts and haven't found any available spider gears that say they're for the Vari-Lok.
After I put a taller lift and slightly larger tires on my '02 Overland, every once in a while I would hear what felt and sounded like a tire rub from somewhere to my right when I was turning. I didn't see any marks, but I cut the bumper a little because I could see it was going to rub while flexing. Same sound kept happening, but getting worse over time. I also had a low pitched hum at speed. I changed the wheel bearings. They were bad and it does drive better, but still made the humming noise, as well as the noise when turning. So, I changed the passenger side axle shaft. That didn't help.
Of course, the thing has 180k on it and the diff was in my mind the whole time, but I wanted to try the easier stuff first.
Last week, I heard and felt what I would have guessed was a CV joint. The familiar rubbing sound mixed with a popping sound. Time to park it.
I had hoped it was a mixture of what people call chatter out of the diff and maybe the left CV had gone bad. No such luck. I pulled the diff cover and found the spider gears are visibly loose on the center pin.
So... The limited slip works fine. I need bearings, spider gears and a center pin. I can change all that if anyone will sell me spider gears. Bearings are no problem to find at all. Will anybody sell me spider gears?
Thanks for reading.
-Mel
TheZombie is offline
post #2 of 12 Old 10-05-2021, 03:36 PM
WJ60
WJ60's Avatar
Rockauto
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #3 of 12 Old 10-05-2021, 10:34 PM Thread Starter
TheZombie
1993 XJ Cherokee
Originally Posted by WJ60 View Post
Rockauto
They have open diff and Trac Loc spider gears, but no Vari Lok.
post #4 of 12 Old 10-05-2021, 10:50 PM
WJ60
WJ60's Avatar
Amazon, Summit Racing, Quadratec
WJ60 is offline
post #5 of 12 Old 10-06-2021, 06:23 AM
cDee63
cDee63's Avatar
Everybody is out of stock. Vipers and older Vettes also used pretty much the same center section, could not find anything for them either, Viper uses the Hydralok as well though the ring gear bolts are 7/16" vs 3/8" for ours except the early ones which are also 3/8", those are unavailable as well.
CraigMBAx likes this.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #6 of 12 Old 10-06-2021, 12:51 PM
leadsled jeep
leadsled jeep's Avatar
Welcome to real live Atlas Shrugged.
For a WEAK and IGNORANT people, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is online now
post #7 of 12 Old 10-06-2021, 02:33 PM
Sangster
Sangster's Avatar
pull it all out and put an ARB in there.
2004 WJ Overland
2014 WK2 Overland
Sangster is offline
post #8 of 12 Old 10-07-2021, 03:19 PM
cDee63
cDee63's Avatar
Even the axle shafts for that are hard to find, and they have to be changed going from Vari Lok to ARB.
cDee63 is offline
post #9 of 12 Old 10-08-2021, 11:26 AM
Sangster
Sangster's Avatar
They aren't hard to find at all. Rockauto has them, Autozone, Advance, Napa.....
cDee63 likes this.
2004 WJ Overland
2014 WK2 Overland
Sangster is offline
post #10 of 12 Old 10-09-2021, 06:46 AM
cDee63
cDee63's Avatar
It certainly seems they have them now, last year was different, could not find them anywhere. I do see they have both versions, stripped and dressed. Thanks for the heads up, I am buying a set now.
Sangster likes this.
cDee63 is offline
post #11 of 12 Old 10-12-2021, 12:29 PM
CraigMBAx
CraigMBAx's Avatar
Except Atlas was the end of long supply chains, and holding minimal inventory JIT style.
1999 WJ Limted - Ex Soccer Mom ride turned Rule 25 Compliant Bike Hauler
CraigMBAx is offline
post #12 of 12 Old 10-13-2021, 05:12 AM
leadsled jeep
And Hank Reardon hung in there as long as he could with a corrupt government and populace intent upon stealing his labor and inventions. John convinced him to let it all go and see how they manage in their own without personal responsibility and work ethic. Reminds me MUCH of today and supply lines having trouble and people who want to mooch off the work of others. Seems Ayn Ryan was quite prescient.
We are only missing that copper based superalloy.
