Valvoline 75-140 Gear oil For Axles - JeepForum.com
 1Likes
  • 1 Post By LumberjackLloyd
post #1 of 12 Old 08-06-2020, 06:50 PM Thread Starter
blueseasons1
Its time to change my axle juice. 04 with Qudra Drive. the last time I use Amsoil at 20 bucks a quart.. It has the friction modifier added. I was looking for a cheaper alternative and Red Line is also 20 bucks a quart.I see Valvoline claims to have the FM built in as well and its $13 a quart. I know everybody has their preferred brands and products based on experience. I'am considering going the cheaper Valvoline route myself, unless anybody advises against it.
blueseasons1 is offline
post #2 of 12 Old 08-06-2020, 07:37 PM
wranglertec
The Mopar fluids have been supplied by Exxon/Mobile before Chrysler Jeep became FCA. Now the Mopar oils are supplied by Shell/Penzoil. So Valvoline will be just fine.
Sent from my iPhone using Tapatalk
wranglertec is offline
post #3 of 12 Old 08-07-2020, 05:59 AM
Double E
Double E's Avatar
The Valvoline is fine.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #4 of 12 Old 08-08-2020, 06:26 AM
XJ4oh
1997 XJ Cherokee
It’s fine, but you still want to add the Mopar friction modifier.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #5 of 12 Old 08-09-2020, 01:36 PM
coldspit47
My gear shop recommends Lucas (dino) 85w-140 in all their axles, plus FM in clutch style LSD axles. It's all I've ever used, comes out to about $6/qt or $20/gal, plus cost of FM.
JEEP. making mechanics out of ordinary folks since 1940.
coldspit47 is offline
post #6 of 12 Old 08-10-2020, 09:21 AM
GmanWJ
GmanWJ's Avatar
I used the Valvoline before, still needed the Mopar FM.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #7 of 12 Old 08-10-2020, 02:39 PM Thread Starter
blueseasons1
Its supposed to be in it.
post #8 of 12 Old 08-11-2020, 07:49 AM
GmanWJ
GmanWJ's Avatar
So the label says. I put it in thinking the same thing. Within a week it started groaning. Had to add the FM to quiet it back down.
GmanWJ is offline
post #9 of 12 Old 08-11-2020, 01:16 PM
Double E
Double E's Avatar
Usually, it doesn't groan from low FM.
It will ratchet in tight turns or sometimes called "skip" a tire over hard pavement when turning.
But that it was resolved with some FM added is good all the same.
Double E is offline
post #10 of 12 Old 08-11-2020, 02:00 PM
Boojo35
1987 YJ Wrangler
I use Valvoline products faithfully. I do this for a living and have for 40 years.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #11 of 12 Old 08-11-2020, 02:07 PM
LumberjackLloyd
You must be speaking of ECGS! They are on the Lucas bandwagon for sure; not saying that is unwarranted.
In response to the thread, I grab the gallon jug of Walmart 85w-140 conventional and change every 15-20k miles. Diff's aren't picky unless you have a clutch pack, if you do just make sure the grease is already LS safe or get the additive.
coldspit47 likes this.
LumberjackLloyd is offline
post #12 of 12 Old 08-11-2020, 06:15 PM
coldspit47
Indeed! Shame they moved so far out but their new warehouse is HUGE. I picked up my axle from there about week and a half ago.
