Upper radiator hose - JeepForum.com
post #1 of 13 Old 08-01-2021, 08:39 PM Thread Starter
56BelAir
Upper radiator hose
Seems like I replace my upper radiator hose every couple years. What would cause the upper hose to spit like this? Poor product or just too much pressure?
The radiator is about 4 years old and I replaced the thermostat at the same time. I do tow a trailer every now and then, perhaps that causes more heat.
2001 Jeep Grand Cherokee Limited
Red
Spectacular sterosystem
Pretty cool roof rack
4.7 V8
56BelAir is offline
post #2 of 13 Old 08-01-2021, 09:12 PM
GmanWJ
GmanWJ's Avatar
How are your motor mounts? If they are old and squished, they can allow the motor to move around and stress the hose.
I assume you changed the hose clamp because it was leaking and/or the hose popped off? Forum member Harry has a thread about that somewhere nearby ... motor mounts.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #3 of 13 Old 08-01-2021, 09:46 PM
WJ60
WJ60's Avatar
^^ Agree
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #4 of 13 Old 08-02-2021, 04:37 AM
mak_v8
mak_v8's Avatar
I also would vote for poor material....
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is online now
post #5 of 13 Old 08-02-2021, 05:34 AM
HarryH3
No matter how hot your cooling system gets, the radiator cap should release pressure into the overflow long before a hose splits. In 45 years of driving, I've never had a radiator hose split like that. As GmanWJ said, worn motor mounts will let the engine tug at that upper hose quite a bit. Mine was held on with spring clamps, so it just pulled off of the radiator nipple. Screw type hose clamps won't let go like that, so that could be the cause of your issue. Here's the thread that GmanWJ mentioned: https://www.jeepforum.com/forum/f310...-hose-4432877/
HarryH3 is offline
post #6 of 13 Old 08-02-2021, 10:32 PM
jw11432
Good answers here. What brand of hose are you getting? I generally try to stick with Gates on hoses and belts, always have had good luck with them. If it's a bargain brand, that could certainly be part of the issue. And the motor mount theory, flexing things about certainly holds credibility. Looks like it's resting against the shroud.
Upon closer inspection, it looks like the hose is resting right up against the shroud. With motor mount flex, that could feasibly be accelerating wear. Am I seeing that right?
2004 GC Limited 4.7
jw11432 is offline
post #7 of 13 Old 08-25-2021, 02:44 PM Thread Starter
56BelAir
new radiator hose
I installed my new upper radiator hose. You can see where it is rubbing against the radiator shroud when it expands.
I know someone mentioned possible motor mount that is broken.When I see the engine running with the hood open at high RPM, it seems like the engine is stable.
I'm wondering if I should trim some of that radiator shroud away from the hose where it comes up close to it.
PJ
Red
4.7 V8
56BelAir is offline
post #8 of 13 Old 08-26-2021, 04:36 PM
JHenke
PJ
Yes, trim the plastic shroud.
JHenke is offline
post #9 of 13 Old 08-26-2021, 05:57 PM
WJ60
WJ60's Avatar
Motor mount issues won't show up when the motor running at a constant rpm. Have someone press the gas pedal down quickly a few times while your watching the engine. If it rocks back and forth every time then you might want to inspect the mounts.
WJ60 is offline
post #10 of 13 Old 08-28-2021, 02:38 PM
speednjay
speednjay's Avatar
Maybe try a silicone hose set https://www.ebay.com/itm/312066939620
speednjay is offline
post #11 of 13 Old 08-30-2021, 05:06 PM
03WJinAZ
2003 WJ
I bet the radiator is slightly smaller than the OEM one. Or its just not installed right. Trimming the shroud seems like the easiest solution.
I have used Gates hoses with no problems for years. I would say they are a better manufacturer
03WJinAZ is offline
post #12 of 13 Old 08-30-2021, 05:48 PM
CraigMBAx
CraigMBAx's Avatar
Of course it is. There's no load on the engine!
Put it in drive, hold the brakes, and stand on the gas while it's in gear.
Repeat in reverse.
If the motor rocks over, welp, there you go!
1999 WJ Limted - Ex Soccer Mom ride turned Rule 25 Compliant Bike Hauler
CraigMBAx is offline
post #13 of 13 Old 08-30-2021, 11:56 PM
Delta0
I reckon Gates make the best hoses.
As well as what others have said.
When you fit a hose, use a little grease of the spigot so the hose goes on easily.
Make sure the hose lies straight / unstressed.
Delta0 is offline
