Upper Control Arm info - JeepForum.com
post #1 of 15 Old 02-05-2020, 01:54 AM Thread Starter
giacomom
Hi all,
I would like to know if I can to fit the adjustable front upper front control arm of the W rangler TJ to 2002 WJ 4.7 V8 H.O.
thank you
Giacomo
giacomom is offline
post #2 of 15 Old 02-05-2020, 09:16 AM
LuthWJ77
LuthWJ77's Avatar
DM Kolak he probably has access to dimensions of both and can give you an answer. I bet they're pretty close though.
LuthWJ77 is online now
post #3 of 15 Old 02-06-2020, 02:31 AM Thread Starter
giacomom
Thank you LuthWJ77
hopefully Kolak will read my message and reply.....
Giacomo
giacomom is offline
post #4 of 15 Old 02-11-2020, 01:45 AM Thread Starter
giacomom
Hi,
159 views and no response....
too technical question ?
apart from Mr. Kolak has anyone ever addressed the problem ?
thank you
Giacomo
giacomom is offline
post #5 of 15 Old 02-11-2020, 01:59 AM
Kolak
Vendor
Kolak's Avatar
Do you already have the arms? If so, what brand are they?
Is your WJ lifted or stock height?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #6 of 15 Old 02-11-2020, 04:00 AM Thread Starter
giacomom
Thank you Kolak
control arms homemade, but I wanted to fit the double adjuster for caster adjustment
+2,5" lift
Giacomo
giacomom is offline
post #7 of 15 Old 02-12-2020, 01:56 AM
Kolak
Vendor
Kolak's Avatar
What sort of bushings/joints are you using in the arms you made?
or
Kolak is offline
post #8 of 15 Old 02-12-2020, 06:26 AM Thread Starter
giacomom
Classics rubber bushing
Giacomo
giacomom is offline
post #9 of 15 Old 02-13-2020, 03:21 AM
Kolak
Vendor
Kolak's Avatar
Those should work just fine on the WJ. The front upper WJ arms interchange with the TJ/XJ/ZJ easily, assuming you're using stock style rubber bushings.
or
Kolak is offline
post #10 of 15 Old 02-13-2020, 12:51 PM Thread Starter
giacomom
Thank you Kolak
so for example the RK00124 Rock Krawler could be perfect ?
Giacomo
giacomom is offline
post #11 of 15 Old 02-14-2020, 02:07 AM
Kolak
Vendor
Kolak's Avatar
I'm confused... I thought you said you had made your own arms? And that they had rubber bushings?
Originally Posted by giacomom View Post
Thank you Kolak
Giacomo
or
Kolak is offline
post #12 of 15 Old 02-14-2020, 05:56 AM Thread Starter
giacomom
they are home made, but I didn't build them ....
I would like to buy Rock Krawler which are certainly of better quality ....
giacomom is offline
post #13 of 15 Old 02-15-2020, 02:10 AM
Kolak
Vendor
Kolak's Avatar
Well I've seen a lot worse than those homemade arms! Why not give them a try?
or
Kolak is offline
post #14 of 15 Old 02-15-2020, 11:02 AM
Bigrigr
Bigrigr's Avatar
Seriously! If you dont want those "homemade" arms, then i do!
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,3"BBfront,2"BBrear,JK'sW/32's
Bigrigr is offline
post #15 of 15 Old 02-15-2020, 12:18 PM Thread Starter
giacomom
in fact it is exactly what I would like to do ....
buy and to fit the RK00124 Rock Krawlers for Wrangler TJ
Giacomo
giacomom is offline
