tv cable adjust - JeepForum.com
 4Likes
  • 1 Post By 2oldjeeps
  • 2 Post By mikeundi
post #1 of 8 Old 03-06-2019, 04:25 PM Thread Starter
2oldjeeps
tv cable adjust
cant do it like youtube! hard to pull white clip and cant pull cable end off linkage.
my 99 4.0 shifts little higher than b 4, about 2200/2600.
advice?
Photoweborama likes this.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #2 of 8 Old 03-06-2019, 08:48 PM
Photoweborama
1936 CJ2A
advice?
Donít pull the end of the cable off. No reason to do that.
You will have to take the white clip off because it has teeth that lock the cable in position.
Once you remove the white clip, the cable is spring loaded. Press the cable towards the air cleaner box side and let it come back on its own. The stick the white clip back. You are all set.
Sent from my iPad using Tapatalk
Photoweborama is offline
post #3 of 8 Old 03-06-2019, 09:39 PM Thread Starter
2oldjeeps
thats what i wanted to hear.ill warm it up tomorrow and try again.plastic is brittle, chipped already on outside ends. thanks, report back later...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #4 of 8 Old 03-06-2019, 09:50 PM
mikeundi
Be careful; first time I pulled mine off it snapped and got lost in the grass! Not easy to source without buying the entire cable.
Photoweborama and 2oldjeeps like this.
mikeundi is offline
post #5 of 8 Old 03-06-2019, 11:02 PM Thread Starter
2oldjeeps
yeah...it scares me...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #6 of 8 Old 03-07-2019, 12:56 PM Thread Starter
2oldjeeps
ok so im back where i was,no early downshift but 2-3 up is apx 2400. torq lock is ok. od is ok.
who,what controls shiftpoints?
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #7 of 8 Old 03-08-2019, 07:57 AM
LuthWJ77
My brother had a throttle position sensor and idle air control valve both out at the same time and his was shifting badly. Replaced them both and it solved it. Took a long time before it threw a code too but probably the TPS has some input for a downshift when you put your foot in it I would guess.
LuthWJ77 is offline
post #8 of 8 Old 03-08-2019, 11:31 AM Thread Starter
2oldjeeps
this is easy going driving,not hard. it will "sometime" downshift with slight pedal pressure going steady at 40 to 50 mph.
it just seems like this started recently.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
TV Cable Adjustment Slack AMD_GAMER XJ Cherokee Technical Forum 5 12-06-2018 06:41 AM
Heat/Vent Cable Routing mikewiz38 YJ Wrangler Technical Forum 3 11-04-2018 06:53 AM
Adjusting Kickdown Cable or TV Cable!! JustChasee ZJ Grand Cherokee Forum 1 04-02-2018 07:23 AM
parking brake front cable replacement tips PJ03WJ WJ Grand Cherokee Forum 0 04-01-2018 07:04 AM
RER Ipod Cable spolebitski KK Liberty Forum 2 01-04-2018 01:55 PM
