turn signals and blower motor died - JeepForum.com
post #1 of 16 Old 10-05-2010, 12:38 PM Thread Starter
mrbigglesworth
mrbigglesworth's Avatar
ok here is the background on my problem:
2003 Jeep Grand Cherokee 4.0L Engine, Auto Trans, No automatic temp control.
I was driving and I had my A/C on, all the sudden I heard a strange sound coming from the heater vents and my blower motor stopped working and my turn signals died.
This is what I have done so far:
I pulled the blower motor resistor out and saw that it was completely fried, there was a break in the metal as well as some corrosion and cracking, so that is new and replaced now
I pulled out the blower motor and jumped it to the battery, and it works fine.
I have replaced the combination flasher under the dashboard, still no change in my problem
The hazards word fine and there are no fuses blown in the entire Jeep.
Any ideas?
?[]|||||||[] Black 1990 YJ 4.2L 6cyl 5spd []|||||||[]
BLACK JEEP CLUB #1000
Mods:
3.5" Rough Country Lift Kit
2 inch shackle lift
JKS Telescoping front track bar
33"x13.5" Super Swampers with 15" x10" AR Wheels
Front and Rear Auto Lockers
SYE and CV shaft in rear
Motorcraft Carb Conversion
Imperial Electric Cooling Fan
Grill Guard Front Bumper
Hella Bumper Lights
Rear Towing Crossmember and Hitch
Diamond Plate Running Boards
CB Radio
mrbigglesworth is offline
post #2 of 16 Old 10-05-2010, 02:38 PM Thread Starter
mrbigglesworth
update: I took apart the control panel for the a/c and heat, and i jumped the relay that is located in there. This caused the blower motor to start working. I have a new relay on back order with the dealer, now in the mean time what do I do about my turn signals? they still do not work.
Mods:
2 inch shackle lift
Hella Bumper Lights
CB Radio
post #3 of 16 Old 10-05-2010, 08:43 PM
skiebuster
wow, thats crazy. hope you get it fixed. sorry, but I dont have a clue what could be wrong.
skiebuster is offline
post #4 of 16 Old 10-19-2010, 02:48 PM
Shawn1143
My Jeep just did this same thing today when I got off work. Have you been able to fix everything?
Shawn1143 is offline
post #5 of 16 Old 10-20-2010, 12:14 PM Thread Starter
mrbigglesworth
ok, the new relay came and it still does not work, so the only thing i can think of is that there is no power supply to the relay. I know the blower resistor is good, the blower motor is good, and the entire control panel for the heat/air is good. The only thing left I can think of is the air mixture knob(the hot/cold). Where does this knob go? Is there a mixture door/motor some where that needs to be replaced?
Mods:
2 inch shackle lift
Hella Bumper Lights
CB Radio
post #6 of 16 Old 01-04-2012, 12:44 PM
willcla
i was having the same problem. My signals and my blower motor went out at the same time. Also fuse 20 (HEVAC) kept blowing. It turned out to be a wire shorting out. The wire was located on the driver side going into the transmission. The insulation on the wire had rubbed off and the bare wires were touching. I cleaned them and put some electrical tape around them and everything started working again.
willcla is offline
post #7 of 16 Old 03-06-2014, 09:12 PM
cesarcarrion
Wire?
Please can you name the exact position of the wire because my jeep has the same problem and I suspect that I have the same wire problem. But I need more details to fix this. Thanks
cesarcarrion is offline
post #8 of 16 Old 10-23-2015, 07:37 PM
lonestar1982
Bump pictures please
lonestar1982 is offline
post #9 of 16 Old 10-28-2015, 10:30 PM
lonestar1982
Has anyone fixed this issue
post #10 of 16 Old 07-02-2017, 11:12 AM
sjm0913
Hi:
I know this is an old thread but my Grand Cherokee Limited just did the same. I was driving and stopped at gas station, when I put it in park the blower died, the ac control panel died and the turn signals wont work. I checked all fuses, resistor, etc. and still no luck. Any ideas?
Thanks
Steven
sjm0913 is offline
post #11 of 16 Old 09-26-2017, 05:12 PM
seasoned_geek
It's the #20 fuse under the dash. HEVAC. It is a red 10 AMP.
I have not looked for the wires yet.
seasoned_geek is offline
post #12 of 16 Old 12-23-2017, 01:08 AM
livingod101
I have a 2004 Jeep Grand Cherokee Laredo. My blower fan stopped working and left & right signal. I did find that #20 fuse (10A), under the driver dash, did blow, replaced and it blew again. It was a frayed wire to a sensor in the transmission that made it happen!!! GO FIGURE!!!
If you go under the Jeep, on the driver side, above the Transmission pan there is a sensor with 3 wires going to it. I separated them, cleaned with brake cleaner and used electrical tape to cover the frayed piece (which I will replace with liquid electrical tape).
I attached the pic as someone requested.
livingod101 is offline
post #13 of 16 Old 06-03-2018, 05:30 PM
Markkiemark
Hey Bud I’m having the same issue I’m gonna see where it is
Markkiemark is offline
post #14 of 16 Old 06-03-2018, 08:55 PM
Markkiemark
Hey I just uploaded a video on where it is and how you can fix https://youtu.be/tRiG9dlupI4
post #15 of 16 Old 10-20-2018, 10:25 PM
tomwj47
Thanks.this forum help me again.
tomwj47 is offline
turn signals dont work JackStraw WJ Grand Cherokee Forum 15 11-17-2015 08:55 AM
blower motor stuck on? Howiedooit WJ Grand Cherokee Forum 5 03-19-2012 03:58 AM
Lost my Blower motor ScotZ WJ Grand Cherokee Forum 2 06-23-2010 08:42 PM
99 WJ blower motor will not run Go4Lo WJ Grand Cherokee Forum 11 06-01-2010 09:28 PM
fuse help for turn signals and emergency lights that are not blinking straty1987 WJ Grand Cherokee Forum 4 02-08-2009 07:41 PM
