Transmission expects helpppp - JeepForum.com
post #1 of 8 Old 05-15-2020, 07:58 PM Thread Starter
GingahJon
Swapping transmissions in the coming week.. 42re came out of a 97 zj going into a 04 wj. From all that I read it's pretty much plug and play. Tips? Advice? Dos or don'ts?
GingahJon is offline
post #2 of 8 Old 05-25-2020, 04:04 AM
TollyWJ
TollyWJ's Avatar
prefill the torque converter the best you can and always verify the input and output seals bearings and shafts are in good shape. you may as well replace the seals before it goes it as they are an easy switch.
TollyWJ is offline
post #3 of 8 Old 05-25-2020, 07:56 AM
jtec
jtec's Avatar
2014 JK Wrangler
At the least I would
the trans filter,
ATF+4 not universal or 1 type fits all just ATF+4.
Also confirm Transfer case bolts up while on the ground.
jtec is offline
post #4 of 8 Old 05-26-2020, 01:26 PM
cruisingram
So are all 98 Zjs the same trans as the WJ 4re as well? How do I identify if my 98Zj trans is the same?
cruisingram is offline
post #5 of 8 Old 05-31-2020, 01:14 PM Thread Starter
GingahJon
I posted this on the fb page too and they said it souldnt work bc the harness is different and a sensor is different.
post #6 of 8 Old 06-06-2020, 07:04 PM
Swiff
1997-1998 had its own transmission. 1999 has its own transmission (valvebody electronics and some internals). 2000-2004 is the same (Part# 52119837AA the valve body and electronics are the same) This is for the 4.0l 42RE. Although they are all 42RE and bolt up, the valve body and electronics are different in each of the versions.
I did a 42RE complete rebuild. Hope this helps. It has all pictures and videos of complete tear down and rebuild.
Derek
2k WJ Laredo - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
post #7 of 8 Old 06-09-2020, 12:16 AM Thread Starter
GingahJon
Thank you!
post #8 of 8 Old 06-09-2020, 05:26 PM
cruisingram
So you can just swap the valve body and electronics? Which part of the write up deals with that if you have it?
