Transmission compatibility? - JeepForum.com
post #1 of 7 Old 01-11-2020, 08:43 AM Thread Starter
Bee4570
Bee4570's Avatar
In the ongoing saga of me Tony-Starking my 2001 Jeep Grand Cherokee back from the grave, I've often heard, and read, that the 42RE transmission is a weak link in the system, and that the 45RE is a much better transmission, and available behind the 4.7L V8 in the WJ, and that the later 545RE is paired behind Hemi Rams just fine. Well, I figure I might as well do my research now, so is there any dimensional differences between the 45RE and the 545RE? Would the computer throw a fit by me giving it another gear to play with? The transmission was a planned upgrade from the get-go, just something I intend to do down the line.
Or, you know, when it's needed. My roommate asked to borrow my WJ for the day and I know he's a bit stabby on the throttle. He's never driven anything that uses a throttle cable instead of throttle-by-wire. Bless his heart.
Private Sign - Do Not Read
Bee4570 is offline
post #2 of 7 Old 01-11-2020, 09:48 AM
smokeyyank
smokeyyank's Avatar
If you're asking if you swap out the 42re in favor of the 545re found in the V8 no. Really theres nothing to swap in place of the 42re. Agitated pancakes did a swap of a ax15 but was tons of work and has a permanent CEL.
As for the 45re and 545re they are the same tranny just that the 545 had a reflash to allow for a "5th gear".
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #3 of 7 Old 01-11-2020, 10:06 AM
jtec
jtec's Avatar
2014 JK Wrangler
KISS use a 42RE, you are limited as its a 4.0L .
The good news you have the legendary 4.0L engine.
1st mod - install a trans cooler.
jtec is offline
post #4 of 7 Old 01-11-2020, 11:49 AM Thread Starter
Bee4570
Bee4570's Avatar
Welp, this is why I'm askin'. Figure it'd be smarter to ask now, rather than down the line after I dropped $1200 on a rebuilt transmission. Now I know it ain't gonna wanna play nice. Thanks much.
Bee4570 is offline
post #5 of 7 Old 01-11-2020, 12:44 PM
rjbruzan
The bellhousing bolt pattern is different between the 6 and 8 cylinder.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 7 Old 01-12-2020, 07:08 AM
Purcell69
What about the AW-4 from the XJ? You'd still have the permanent CEL, but the AW-4 is a much more resilient transmission than the 42RE for use behind the 4.0.
-Joe
Purcell69 is offline
post #7 of 7 Old 01-12-2020, 11:13 AM
smokeyyank
smokeyyank's Avatar
Pretty sure the war wont work because of the PCM. That would be ideal though wish they would have used the aw4 instead of the 42re.
04 WJ, 4.7HO
