towing my 2x overland - JeepForum.com
 1Likes
  • 1 Post By LuthWJ77
post #1 of 8 Old 03-10-2019, 09:47 PM Thread Starter
enksdad
Hi All,
i have purchased a new motorhome and im planning on towing my wj. can anyone help with tips or tricks in towing this jeep. im not sure about racking up mileage when i tow and obviously i need to have the jeep in neutral, but thats really about the end of it for me. i have heard that wranglers when neutral in the transfer case is selected, they wont increase the mileage. i do have roadmaster tow bar and brackets for it already and will be installing that stuff soon. also any recommendations on braking systems? thanks in advance! Tim
enksdad is offline
post #2 of 8 Old 03-11-2019, 10:55 AM
LuthWJ77
LuthWJ77's Avatar
you say "2X" is that a 2wd model? I've towed mine 4wd several thousand miles odometer does not record additional mileage when towing. If you have 2wd I think you'll need to pull the rear driveshaft transmission in neutral not going to work.
LuthWJ77 is offline
post #3 of 8 Old 03-11-2019, 11:03 AM
cDee63
cDee63's Avatar
The speedo and odo are taken off the rear axle tone ring on the WJ. The transfer case neutral disconnects the transmission, something you want to do towing an automatic vehicle. The transmission pump itself will not be pumping and having a driveshaft spinning the output shaft will cause lack of lube issues internally to the trans.
2004 GC Limited 4.7
2006 Crown Vic Interceptor
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #4 of 8 Old 03-11-2019, 02:11 PM
Photoweborama
Photoweborama's Avatar
Humm. Sounds like the WJ doesnít tow well... no wonder there are so many Suzuki Samuraiís towed by RVís! ;-)
Sent from my iPhone using Tapatalk
Photoweborama is offline
post #5 of 8 Old 03-11-2019, 02:18 PM
LuthWJ77
LuthWJ77's Avatar
Mine tows great. Towed it from Houston to Red River NM about 1800 round trip, few hundred of that steep mountain roads, behind F250 diesel barely could tell it was there. With that said, need to make sure you understand how to do it correctly. I'd rather buy a trailer for my WJ than have a Suzuki anything.
LGrocks likes this.
LuthWJ77 is offline
post #6 of 8 Old 03-11-2019, 08:52 PM
LGrocks
1936 CJ2A
The WJ tows great if itís a 4x4. My Dad has about 4K miles towing his 02 four down behind his motorhome. Only issue we ever had was death wobble while towing. Leave it up to a Jeep to get death wobble all by itself, even without a driver.
As has been said, you gotta have the transfer case to completely disconnect the trans from the axles.
You might check out an owners manual that is specific to a 2WD WJ. See what it says about flat towing.
LGrocks is offline
post #7 of 8 Old 03-12-2019, 06:10 AM
paintballtruck
1979 J-Series Truck
pull the driveshaft out and wont be a problem then just pop it back in when you get where you are going
paintballtruck is offline
post #8 of 8 Old 03-12-2019, 07:06 AM
99sajeep
99sajeep's Avatar
2005 WK
The problem with pulling the driveshaft is that with enough of an incline (it doesn't take much), you'll lose transmission fluid out of the back. Unless you put a plug/cap in the tailshaft housing.
'99 WJ 4x4 Ltd 4.7L (sold)
'05 WK 4x4 Ltd 5.7L (mine) 200k+ club
'01 WJ 4x4 Laredo 4.7L (daughter)
99sajeep is offline
2018 grand Cherokee altitude and towing pauliewoz Trailers & Towing 5 08-22-2018 05:52 AM
Trade my 2012 Overland for 2017 or 2018 Summit X54TH WK2 Grand Cherokee Forum 25 07-16-2018 07:41 AM
Towing with my TJ Narbler TJ Wrangler Technical Forum 9 06-08-2018 04:42 AM
Major Confusion on Towing Capacity! CAGB3362 WK2 Grand Cherokee Forum 6 06-06-2018 01:09 PM
M100 Trailer For Overland Use, Looking for Input FireGuy1996 JK Wrangler Technical Forum 12 02-05-2018 04:59 PM
