Thud when parked, not running. - JeepForum.com
 2Likes
  • 1 Post By jw11432
  • 1 Post By GmanWJ
post #1 of 7 Old 09-02-2021, 05:04 PM Thread Starter
Ravenbar
I felt/heard a hard thud when I was parked getting cleaned up after work before going in a store.(drove about 3 miles from work to the store) Similar sound/feeling to hitting a bad pothole. My first thought was a co-worker had spotted me and was pranking me, but no one was anywhere near the Jeep.
Engine was shut off.
I looked underneath and did a walk around and saw nothing unusual and no unusual things happened on my way home either.
My only thought is that something in the suspension was bound up slightly and expanded due to heat. As it cooled, it popped loose.
Any ideas?
Project Thumper:
KD2QQF
Member of Fourth Coast Jeeps
Ravenbar is offline
post #2 of 7 Old 09-02-2021, 10:32 PM
jw11432
Check out springs. That's the only thing I can think of that has any kind of tension. Because if you've got other suspension components getting some binding, that's something you'll want to address ASAP. Perhaps the spring rubber bottom pads (the term is escaping me...isolators?) could have broken and been forced out, which could explain the suddenness of the pop, especially something you could feel.
WJ60 likes this.
2004 GC Limited 4.7
jw11432 is offline
post #3 of 7 Old 09-03-2021, 07:48 PM
GmanWJ
GmanWJ's Avatar
Thinking springs too. Maybe you partially dropped a coil out of the isolator so it reseated off to the side a hair. Then while you were sitting there it just ... slid into place. Maybe. Wild guess.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #4 of 7 Old 09-05-2021, 08:38 AM
Delta0
Did your car move up or down when the noise happened?
Delta0 is offline
post #5 of 7 Old 09-06-2021, 08:34 AM Thread Starter
Ravenbar
Spring isolators all look find and are only a few years old. I'm starting to think it might have been something other then the Jeep making the noise.
Originally Posted by Delta0 View Post
Did your car move up or when the noise happened?
I just felt a small bump, like someone closed a door hard.
Project Thumper:
KD2QQF
Ravenbar is offline
post #6 of 7 Old 09-06-2021, 08:52 AM
GmanWJ
GmanWJ's Avatar
Gremlins, or cosmic rays.
Forget about it until it happens again.
Delta0 likes this.
Dual Batteries
GmanWJ is offline
post #7 of 7 Old 09-06-2021, 01:38 PM
Delta0
I'm with G.
Delta0 is offline
