threads/rpms-drop-or-stalls-when-put-in-gear-on-a-cold-start - JeepForum.com
 1Likes
  • 1 Post By ozyaus
post #1 of 6 Old 06-17-2021, 12:44 AM Thread Starter
ozyaus
Engine stalls on braking once or twice after starting from cold. After that it is OK for the rest of the drive. The running is rough as if about to give up before the stall.
Being an absolute novice, was wondering if anyone has any feedback on using -
Lubegard Instant Shudder Fix, as I suspect it may be the Torque Converter
ozyaus is offline
post #2 of 6 Old 06-17-2021, 07:41 AM
jtec
jtec's Avatar
2014 JK Wrangler
when you feel the stall is about to happen shift to N - did the engine smooth out?
A TCC solenoid issue would likely set a DTC - maybe SCAN for codes.. thise trans codes may NOT show up with the key on off code check. and trans codes may not set CEL to on.
jtec is offline
post #3 of 6 Old 06-17-2021, 03:32 PM Thread Starter
ozyaus
Will try that and let you know, BTW the time to react to this is almost momentary!
ozyaus is offline
post #4 of 6 Old 06-17-2021, 10:43 PM
sparky636
sparky636's Avatar
Check your tranny fluid level. I had a similar issue in the past.
sparky636 is offline
post #5 of 6 Old 06-18-2021, 07:12 AM
cDee63
cDee63's Avatar
Mine was doing the same though would not stall, rpm's would drop to around 400 or even less sometimes and then climb back up to normal. I replaced the PCM for a different issue and that fixed it for awhile. However recently I noticed it doing it again on occasion though not as drastic as prior to the PCM fix.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #6 of 6 Old 06-24-2021, 01:34 AM Thread Starter
ozyaus
sparky636, you are a champ - absolutely right on the solution!
Discovered that the 2 slender rubber hoses connecting the transmission oil cooler underneath the radiator had sprung a leak and the transmission oil had drained off. The DIPSTICK was bone dry - so that explains why it was running fine after a few stops - must have been running OK with the with the sump wash after the transmission warmed up.
Replaced the rubber hose pinch clips with C Hose clamp that screws tight and topped up with
Penrite FS MultiVehicle ATF
Lucas Transmission Fix Stop Slip 700mL
Been running a week without issues, fingers crossed!
sparky636 likes this.
ozyaus is offline
