Those exhaust manifold bolt(s) broken yet? - JeepForum.com
View Poll Results: At what point did your exhaust manifold bolts break?
0 - 14,999 Miles 0 0%
15,000 - 29,999 Miles 0 0%
30,000 - 44,999 Miles 0 0%
45,000 - 59,999 Miles 1 6.67%
60,000 - 74,999 Miles 2 13.33%
75,000 - 89,999 Miles 2 13.33%
90,000 - 104,999 Miles 2 13.33%
105,000 - 119,999 Miles 3 20.00%
120,000 - 134,999 Miles 3 20.00%
135,000 - 149,999 Miles 1 6.67%
150,000 - 164,999 Miles 1 6.67%
165,000 - 179,999 Miles 0 0%
180,000 - 194,999 Miles 0 0%
195,000 - 209,999 Miles 0 0%
210,000 - 224,999 Miles 0 0%
225,000 - 239,999 Miles 0 0%
240,000 - 254,999 Miles 0 0%
255,000 - 269,999 Miles 0 0%
270,000 - 284,999 Miles 0 0%
285,000 + Miles 0 0%
Voters: 15. You may not vote on this poll
post #1 of 7 Old 03-20-2012, 02:52 PM Thread Starter
00JGC00
It's a common problem for the driver-side rear exhaust manifold bolt(s) to break on the WJ's. If yours have broken, what was the mileage when they went?
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: https://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #2 of 7 Old 03-20-2012, 03:14 PM
780406jeeper
It gets worse than that. I am going to assume that very few people actually put a straight edge across the manifold once the rear bolts have broken to determine just how warped the manifold is. I took mine to a machine shop to get trued up and they couldn't, the manifold was too warped. Most just put the new gasket in and tighten with new bolts. Thankfully the gasket is pretty thick and has some crushability to it to compensate.
Kevin
'78 Cherokee Chief: 360/TH400/NOS QT, '04 Grand Cherokee: 4.7/545RFE/242HD w/SYE, JK Rubi front axle, 4.56 gears, Protofab rear bumper/tire carrier
780406jeeper is offline
post #3 of 7 Old 03-20-2012, 04:44 PM
oaklyjeep10
oaklyjeep10's Avatar
Mine did at about 200k
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #4 of 7 Old 03-20-2012, 05:16 PM
smunns
You like polls; don't you?
Mine broke around 106k. One of the easiest fixes I've had to do so far.
smunns is offline
post #5 of 7 Old 03-20-2012, 06:18 PM
Buck89
Mine went around 50k I think and one bolt sheared off flush with the block so I had to drill and extract it out, not the easiest fix that I have had.
Buck89 is offline
post #6 of 7 Old 03-20-2012, 06:46 PM Thread Starter
00JGC00
00JGC00 is offline
post #7 of 7 Old 03-20-2012, 07:20 PM
mtb_crzd47
I put 95k-whatever since I bought it with 101k and they were already shot. smunns, I hope it goes as easily for me as it did you!
2000 WJ LTD Shale Green metallic, stock for now
2007 Yeti AS-X, Avid Code 5's Rockshox Totem,
SOLD: 91 XJ
mtb_crzd47 is offline
Sway Bar bushing bolt Broken help! SKI_VT WJ Grand Cherokee Forum 54 12-03-2015 08:39 AM
Broken Thermostat upper bolt thisguyhasadd2 WJ Grand Cherokee Forum 1 12-20-2011 04:15 PM
Broken Exhaust Manifold Stud Bubba3200 WJ Grand Cherokee Forum 15 09-26-2011 06:59 PM
broken shock mount bolt... AGDubyaJ WJ Grand Cherokee Forum 5 11-03-2010 12:27 AM
Help with broken bolt holes Charlestennison WJ Grand Cherokee Forum 21 04-30-2010 12:07 PM
