Temp stays at 210 - JeepForum.com
 1Likes
  • 1 Post By Uniblurb
post #1 of 10 Old Yesterday, 12:18 PM Thread Starter
Tlando
Tlando's Avatar
Temp stays at 210
Whether at idle or going down the road the temp gauge stays at 210 or just a hair above it. I’ve let it idle for 40 minutes and then took it up and down the road and back and let it idle another 10 minutes and it still stayed at 210. I know the stock thermostat is a 190* and I hear these 2002 WJ’s run a little hotter with the 4.7 V8. I have a hydraulic fan if anybody has any insight let me know please.
Tlando is offline
post #2 of 10 Old Yesterday, 12:46 PM
Photoweborama
1936 CJ2A
Well.. I have a 4.0 with a new thermostat. The fan relay went out and it was almost overheating at idle..
With the relay replaced. Mine sticks at 210 as if the needle was broken there.
As far as I know, thats the perfect temperature...
Photoweborama is offline
post #3 of 10 Old Yesterday, 12:47 PM
2oldjeeps
you can confirm with obd2 scan tool. mine reads 195-200.
look close,mine wiggles a needle width as t stat opens/closes slightly. its on the nose!!
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #4 of 10 Old Yesterday, 12:59 PM
jtec
2014 JK Wrangler
Dash gauges are notoriously inaccurate, they are buffered and skewed.
Are the Fans operating and no codes stored.
the gauge is showing cold first start of day, then slowly climbs to 210 - so far so good IS there a concern?
AC or defrost have any fan speed change?
Those hyd fans tend to spin slowly even when not commanded on.
jtec is online now
post #5 of 10 Old Yesterday, 01:02 PM Thread Starter
Tlando
Tlando's Avatar
Yes the fan just doesn’t seem to spin that fast at all when temp gets up there it stays the same speed from start up to **** off.
Tlando is offline
post #6 of 10 Old Yesterday, 01:46 PM
Uniblurb
Uniblurb's Avatar
The stock thermostat is 195*F rather than 190*. Regardless, just keep in mind the spec of the thermostat is just the temp when it opens and not what temp the engine/cooling system is going to be on the temp gauge.
210F is about optimum for these engines and you're likely fine with it just above this temp. If the coolant hasn't been changed for a while you could flush the system, add a new thermostat and new coolant, but you may just end up with the same temp you have now.
2oldjeeps likes this.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #7 of 10 Old Yesterday, 03:01 PM
2oldjeeps
i consider jeep guages very good.my 3 jeeps look alike ,stable. even with autozone oil sender i get same reading as old sender when good. that the only sender i changed in all three. 130,000 144,000 and 180,000 miles.
i trust them,temp checked with obd2 scan.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 10 Old Today, 03:54 AM
cDee63
cDee63's Avatar
The temp gauge in my 04 reads about the same, and the temp according to my Torque app runs between 198-205 while driving around town. It's the oil pressure that is bogus, it is not a gauge on mine. Looks like a gauge however is a glorified idiot light that will show the same reading unless the pressure is only a couple psi, then a warning. A little late I would say.
2004 GC Limited 4.7
2006 Crown Vic Interceptor
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #9 of 10 Old Today, 07:34 AM
Sprung99GC
Sprung99GC's Avatar
Oil pressure gauge works as it should on my 99 4.7. Goes up to 60psi when cold and then down to 40psi when at hot idle. Around 50psi when going down the road. I wonder if the was a change in the newer ones.
Sprung99GC is offline
post #10 of 10 Old Today, 07:42 AM
FanTech
There can also be differences in the temp sensors. On my old 4.0L I changed out the temp sensors and the temp shifted by 5-10 degrees.
FanTech is offline
Temp Gauge V3RB0S3 Jeep CJ Forum 1 03-03-2019 12:47 PM
Troubleshooting temp gauge or sending unit with a few variables dadbod30 Jeep CJ Forum 7 01-16-2019 04:34 PM
High Engine Temp Dilemma Kidso XJ Cherokee Technical Forum 20 08-26-2018 04:30 AM
1994 YJ temp fluctuates a lot jhw528 YJ Wrangler Technical Forum 21 02-09-2018 10:29 AM
