Temp of properly cooling A/C? - JeepForum.com
 1Likes
  • 1 Post By Jeeples
post #1 of 6 Old 07-11-2019, 10:26 PM Thread Starter
Jeepsmsc2
If a thermometer is placed in a WJ vent which has properly working A/C, what should the temperature be for:
A) Recirculate dash vents
B) Dash vents (non-recirculating)
The reason I ask is I want to measure the temperature of mine and want to compare to a correct known reference temperature to mine is working at spec.
Jeepsmsc2 is offline
post #2 of 6 Old 07-12-2019, 08:24 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
You're looking for 28-30* below ambient temps...any cooler than that and you run the risk of icing up the evaporator core.
EDIT:
To add to that, when measuring vent temps you always want to 'tax' the system, this means A/C on full blast, all doors open and on recirc. If you're in the 28-30* below ambient temp range out of the vents then your AC is good to go. It's also generally advised to hold the engine RPM slightly above idle, usually 1200 RPMS or so.
99sajeep likes this.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is online now
post #3 of 6 Old 07-12-2019, 11:36 AM
99sajeep
99sajeep's Avatar
2005 WK
^^ this...
'99 WJ 4x4 Ltd 4.7L (sold)
'05 WK 4x4 Ltd 5.7L (mine) 200k+ club
'01 WJ 4x4 Laredo 4.7L (daughter)
99sajeep is offline
post #4 of 6 Old 07-12-2019, 07:43 PM
2oldjeeps
the coldest i see is 38 in 2 different cars
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #5 of 6 Old 07-13-2019, 10:55 AM
Uniblurb
Uniblurb's Avatar
Some real good info from Jeeples. I just fully recharged my 04 4.7 AC system and have center vent temps around 43-44F which seems plenty cold enough. Real long post/thread below but the vent temps are going to vary some depending on ambient temps along with humidity (see below chart).
https://www.jeepforum.com/forum/f310...l#post40677475
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 6 Old Yesterday, 12:49 PM
DJCantonGA
DJCantonGA's Avatar
I was curious, so I stuck a few thermometers in my vents today while out. I'm in north GA, and the outside temp ranged between 89-93. The lowest temp I read from the center vent was 42.4. At 90-91 it averaged 43 at the vent. On the way home, it was 93 outside, and the center vent on fan speed #3 was reading 44.5-46. I'll take it!
I had my system evacuated and charged to spec last year, and replaced an A/C switch.
DJCantonGA is offline
