T-case and diff fluid for 04 WJ? - JeepForum.com
 12Likes
  • 3 Post By SD Overland
  • 2 Post By Uniblurb
  • 3 Post By JoMc67
  • 4 Post By Valentine1
post #1 of 14 Old 03-08-2021, 10:34 AM Thread Starter
Valentine1
Valentine1's Avatar
Hi everyone,
I have an 04 WJ 4.0 w/ 42re. The only fluid flushes I have not done since owning the vehicle (100k miles) are the diff fluid, t-case and power steering.
The friction modifier posts for the diff fluid are throwing me off TBH..
Can anyone recommend the proper diff fluid and TCase fluid for my vehicle? Nice weather this weekend and I've been meaning to get this done
Thanks as always. Love this forum
Jeff
'04 WJ Special Edition 4.0 w/ 42re. Kumho AT-51's
Valentine1 is offline
post #2 of 14 Old 03-08-2021, 11:49 AM
Sangster
Sangster's Avatar
Which TCase do you have? Selectrac 242? Quadratrac/Quadradrive 247?
Sangster is offline
post #3 of 14 Old 03-08-2021, 12:27 PM Thread Starter
Valentine1
Valentine1's Avatar
Oops duh that would have helped to include
I havethe quadratrac 247J. Just hopped under and checked
post #4 of 14 Old 03-08-2021, 03:22 PM
SD Overland
SD Overland's Avatar
Here are ALL the correct fluid specs for a WJ
http://www.wjjeeps.com/service/maintenance_wj.htm
Do some reading on that website, it has all the answer you seek.
Since you don't have Quadradrive, you do not have vari-lok axles and do not need friction modifier. Assuming your axles are stock, of course.
Your transfer case requires a special oil which you can purchase on Amazon.
2004 WJ Overland 4.7 HO, Quadradrive, Onyx Green Pearl Coat
IRO Rock-Link 3'' front, HD short arms rear, Billstein 5100's
265-70R17 Falken Wildpeak AT3, Spidertrax 1.5'' wheel spacers
SD Overland is offline
post #5 of 14 Old 04-16-2021, 01:05 PM Thread Starter
Valentine1
Valentine1's Avatar
I did my TCase last week and it was simple enough! I'm having trouble though and am psyching myself out on that website linked above.
Looks like for the front, Dana 30 I need SAE 75W-140 Synthetic for a 1999-2004 without Varilock
However the two axels listed for the rear say SAE 75W-140 Synthetic is for heavy-duty or trailer use, and to otherwise use SAE 80W-90.
I did notice my rear axel has that 'tag' on it between two of the bolts.. I was hoping to be able to read it but couldnt.. might have to take it off first to read. Was hoping to get the fluid before taking the cover off as it's my only car and I cant get to Autozone if the cover is off! Lol
Am I reading that correctly? I plan on doing both diff covers tomorrow.
Thanks as always fellas
post #6 of 14 Old 04-16-2021, 02:36 PM
underscore
Well do you tow a big trailer or haul heavy loads frequently?
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #7 of 14 Old 04-16-2021, 02:57 PM Thread Starter
Valentine1
Valentine1's Avatar
Lol I see where you’re going with this. No I don’t. No hitch at all haha
post #8 of 14 Old 04-16-2021, 06:12 PM
Uniblurb
Uniblurb's Avatar
Install 75W-140 synthetic in both the front and rear axles. The dealers around here don't even mess with 80-90W gear oil in our axles. Not that they know what they're doing but best to be better prepared for any harsh conditions than under-prepared.
blueseasons1 and Valentine1 like this.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #9 of 14 Old 04-17-2021, 08:54 AM
blueseasons1
I do the 75-140 synthetic in both front and back of mine. Minimal price difference and no other reason not to. I use the lowest price juice I can find and around here its the Valvoline. I have the 247.
blueseasons1 is offline
post #10 of 14 Old 04-18-2021, 07:34 PM Thread Starter
Valentine1
Valentine1's Avatar
Thank you fellas! Didn't get a chance to do the diff's this weekend.. went skiing lol. Next weekend! Appreciate your responses!
post #11 of 14 Old 04-24-2021, 06:30 AM Thread Starter
Valentine1
Valentine1's Avatar
Fellas, I went to autozone today. The Valvoline 75w-140 is plentiful in the 1qt bottles. Every bottle on the shelf says it has the “limited slip modifier”... my question is even without varilock, is that modifier OK for my axles? Not a single 75w-140 on the shelf was plain old synthetic without the limited slip modifier. Maybe I’ll try advance auto parts ?
post #12 of 14 Old 04-24-2021, 07:38 AM
JoMc67
Your fine having 'Limited Slip Modifier' in your WJ, even if you don't require it.
JoMc67 is offline
post #13 of 14 Old 04-24-2021, 09:53 AM Thread Starter
Valentine1
Valentine1's Avatar
THANK YOU!!! I will go back today to buy it all. Plan is to knock it out tomorrow.
post #14 of 14 Old 04-25-2021, 04:40 PM Thread Starter
Valentine1
Valentine1's Avatar
got'er done today fellas! Both front and rear. Lots of brake kleen, lots of shop wipes, lots of scraping and scuffing.. I ended up using the black RTV because I hate seeing those obnoxious colors on some differentials lol. Valvoline makes these real neat flexible plastic bottles for the stuff to squish it into tight places. 75w-140 was plentiful at Autozone
Magnet in the rear diff wasn't too covered with shavings
I waited entirely too long to do the diffs! Poor Jeep =(
Uniblurb, underscore, WJ60 and 1 others like this.
