Stupid tone rings/abs crap - JeepForum.com
 1Likes
  • 1 Post By 97Mule
post #1 of 9 Old 04-29-2019, 07:20 AM Thread Starter
MGDWJ
MGDWJ's Avatar
So a little bit over a week ago I swapped axles in my WJ. I went with a 2004 Ford F350 Dana 60 and a 2005 Chevy 2500 HD gasoline 14 bolt with factory disc brakes and emergency brake. Long story short is I cannot get my Jeep to read the tone ring signal coming from the super duty axle. originally I just wired in the front sensors to the front axle through all my research I have read that it doesn't matter which and sensor you have is long as one of them is hooked up you will have speedometer. I then wired in both the front abs tone ring to see if that would help did not help at all. I then wired the front and the rears to the front abs tone ring so that all four should be getting the same signal and still not work. Anyone have any insight?
MGDWJ is offline
post #2 of 9 Old 04-29-2019, 08:04 AM
97Mule
97Mule's Avatar
When i put my dana 44 in front i just spiced in the wires on both sides. No abs light!
97Mule is offline
post #3 of 9 Old 05-15-2019, 06:10 AM Thread Starter
MGDWJ
MGDWJ's Avatar
Victory!!!! I finally got my speedometer working.
MGDWJ is offline
post #4 of 9 Old 05-15-2019, 07:46 AM
97Mule
97Mule's Avatar
What did u do? Others might need or learn from ur experience.
2oldjeeps likes this.
97Mule is offline
post #5 of 9 Old 05-15-2019, 10:50 AM
2oldjeeps
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #6 of 9 Old 05-15-2019, 02:02 PM
97Mule
97Mule's Avatar
@MGDWJ , Amarillo by morning........ Well , how did u fix?
97Mule is offline
post #7 of 9 Old 05-15-2019, 04:09 PM Thread Starter
MGDWJ
MGDWJ's Avatar
I tapped into my np231 for speedometer signal. Then wired into my abs harness to get the signal to my pcm and on to the dash FWI a WJ with 4.88 gears and 37's it takes a 39 tooth speedo gear. Speedo is now about 1 mph off.
MGDWJ is offline
post #8 of 9 Old 05-16-2019, 08:55 AM
97Mule
97Mule's Avatar
Glad u got it figgered out!
I never look at the speedo, when i tilt the wheel i cant see it. I just use glance over at the gps we have on the dash.
When i see red & blue lights in the mirror, i know i'm going to fast!
97Mule is offline
post #9 of 9 Old 05-16-2019, 12:58 PM Thread Starter
MGDWJ
MGDWJ's Avatar
Not having the speedo input to the pcm was making my tranny shift funky and I noticed a reduction in power and throttle response
MGDWJ is offline
Custom Tone Ring wireman121 TJ Wrangler Technical Forum 3 12-02-2018 04:48 PM
2017 GC reverse sensor tone stuck on 2008OverlandCRD WK2 Grand Cherokee Forum 6 08-19-2018 06:30 PM
4.7 HO Tone Ring swap fl_jeep WJ Grand Cherokee Forum 7 05-30-2018 08:38 AM
