Stock sound system upgrade? - JeepForum.com
post #1 of 55 Old 09-19-2015, 05:42 AM Thread Starter
BlackWidowWJ09
Has anyone done a sound system upgrade and bypassed the stock amp by putting in a new Head Unit and Amp in? Also upgrading door speakers. I haven't been able to find anything to help me out...
"Edit" eliminate the stock amp if possible....
BlackWidowWJ09 is offline
post #2 of 55 Old 09-19-2015, 06:07 AM
james_2k
2003 WJ
erm, have you seen the thread literally next to this one? about audio upgrades?
james_2k is offline
post #3 of 55 Old 09-19-2015, 06:22 AM Thread Starter
BlackWidowWJ09
I read through it but he didn't eliminate the stock amp..... that's what im trying to do..
post #4 of 55 Old 09-19-2015, 06:32 AM
james_2k
2003 WJ
there are a load of threads around if you do a bit of googling, i didnt bother when i upgraded mine but good luck!
james_2k is offline
post #5 of 55 Old 09-19-2015, 06:36 AM Thread Starter
BlackWidowWJ09
So you just left it and everything worked fine? I think mine is toast is why im trying to find out... and thanks ill continue digging
post #6 of 55 Old 09-19-2015, 06:39 AM
james_2k
2003 WJ
yeah it worked ok, i only changed headunit and dash speakers along with adding a sub amp. worked fine with the infinity.
james_2k is offline
post #7 of 55 Old 09-19-2015, 06:44 AM Thread Starter
BlackWidowWJ09
Ok thank ya sir I appreciate it
post #8 of 55 Old 09-19-2015, 11:11 AM
Thegdog
If your referring to my build, I did replace the stock amp with an Alpine PDX-F4.
With all the reading I have done, and a little experience, most of the stock stuff doesn't play well with after market. So I decided to start from scratch. I just wish Head units didn't look so Busy and flashy.
Thegdog is offline
post #9 of 55 Old 09-19-2015, 11:32 AM
james_2k
2003 WJ
agreed, even expensive headunits quite often look cheap and too flashy!
james_2k is offline
post #10 of 55 Old 09-19-2015, 12:30 PM
thecause17
thecause17's Avatar
When I replaced my stock head unit, I left everything else the way it was and it sounds great. I think the amp only becomes a a possible issue when you start replacing speakers. Even that, I think I remember reading as long as you pay attention to the speaker impedance values that it can still work fine.
'04 Columbia 4.7HO - SOLD
thecause17 is offline
post #11 of 55 Old 09-19-2015, 12:42 PM
Thegdog
Yep, and I don't understand it. Maybe I should start my own company. lol
Its also going to depend on how loud you want to get. The stock system isn't super loud. Nothing replaces good clean power. And thats something the stock system doesn't have much of. Its just about what you want your wanting to accomplish with your upgrade.
Thegdog is offline
post #12 of 55 Old 09-19-2015, 12:49 PM
ShinyWJ
OP, here's the Infinity amp wiring diagram so you can wire up an aftermarket amp in its place.
ShinyWJ is offline
post #13 of 55 Old 09-19-2015, 12:59 PM
Thegdog
There is also a amp bypass harness from metra, if you don't want to splice into the harness.
Thegdog is offline
post #14 of 55 Old 09-19-2015, 01:13 PM Thread Starter
BlackWidowWJ09
Yall are awesome! I guess i had to ask the right questions for yall to.understand what i was talkin about but im glad it got straightened out! I do plan out completely removing the stock amp, i plannon going with a decent Kenwood HU, then all Kenwood door speakers and then for the amp just a 400w Kenwood amp.
post #15 of 55 Old 09-19-2015, 02:34 PM
Thegdog
OH! One other advice I have. Don't buy an amp wiring kit. Just get a spool of power wire from XS power or sky high car audio. Then buy a fuse block and RCAs separately. If you don't ever plan to do a sub amp. You might could get away with 8awg.
Thegdog is offline
