Steering Wheel change - JeepForum.com
 5Likes
  • 1 Post By Double E
  • 1 Post By 99sajeep
  • 1 Post By zephyr424
  • 1 Post By ParkerStovall42
  • 1 Post By sdg3205
post #1 of 12 Old 03-15-2019, 08:43 AM Thread Starter
frankencat
So the steering wheel on my 2000 WJ Limited is toast. The rubber has completely worn off down to the metal. I found a few used ones on line but it got me wondering how hard is it to replace? I have done a few in the past but not with all the gadgets they have now. Anyone changed one out on a Limited?
2000 WJ 4.7 4x4 Limited
1996 XJ 4.0 Sport (totalled)
frankencat is offline
post #2 of 12 Old 03-15-2019, 09:17 AM
Double E
Double E's Avatar
Super easy. Undo the bolts from the back (8mm I think), the center nut, then use a 2 or 3 jaw puller to remove the wheel.
A junk yard will have a replacement for you. One from a Limited or Overland would be a nice upgrade.
Installation is plug n play. Just be sure to match up the connectors from the clock spring correctly.
Probably a good idea to disconnect the battery to ensure the airbag is not a potential issue.
I have the original from my '04 Freedom that I can send... it is in good shape. I swapped in a Limited one a few years back. Make an offer.
Mattyjm likes this.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 12 Old 03-15-2019, 11:42 AM
99sajeep
99sajeep's Avatar
2005 WK
Make sure your wheels are pointed straight before you pull the steering wheel off. Also, a good idea to disconnect the battery with your lights on. It'll help drain any reserve voltage from capacitors and eliminate potential airbag issues. You'll have a small wire plug to disconnect for the air bag, and one for the steering wheel controls.
You might be able to fit a 3-jaw puller on there, but I've had an easier time with a 2-jaw. When the puller gets real tight, just keep going...it'l eventually pop!
Mattyjm likes this.
'05 WK 4x4 Ltd 5.7L (mine) 200k+ club
'01 WJ 4x4 Laredo 4.7L (daughter)
99sajeep is offline
post #4 of 12 Old 03-16-2019, 09:59 PM Thread Starter
frankencat
Thanks guys. This is on a 2000 Limited.
post #5 of 12 Old 03-17-2019, 04:30 PM
zephyr424
I rented a 3 jaw puller from Advanced Auto and could not get the wheel off no matter how I tried. Bought a vintage 6' Craftsman 2 jaw puller from eBay after reading an old thread and it came off so easy I was shocked. Almost like butter.
There is a guy on eBay from Poland who takes wj steering wheels and wraps them in new leather. I bought one a couple months ago and am very happy with it. Cost $250 which is less than half price for comparable work in the US.
99sajeep likes this.
zephyr424 is offline
post #6 of 12 Old 03-18-2019, 09:40 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
WJ steering wheels can be tricky to remove, there is of course a special tool to use, however as mentioned a 2 jaw puller works great.
I like to apply a decent amount of tension to the center screw and then smack it with 2.5 lb mini sledge, then apply more tension to the center screw and smack it again. Usually after 1 or 2 times the steering wheel pops right off.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is offline
post #7 of 12 Old 02-26-2020, 10:49 PM
sdg3205
sdg3205's Avatar
Im just pulling steering wheels right now. I didn't realize that my standard Lisle 4500 steering wheel puller wouldn't work. I'll grab one those two jaw pullers, looks perfect.
sdg3205 is offline
post #8 of 12 Old 02-27-2020, 01:19 AM
Ralph77
Don't know how a WJ would compare with an XJ but at my Napa we rent tools.
The one we rent has everything I needed to pull the one in my '00 XJ.
Ralph77 is offline
post #9 of 12 Old 02-27-2020, 01:28 AM
sdg3205
sdg3205's Avatar
We have a store up here in Canada that does that program but the tools and sets are often incomplete or broken.
sdg3205 is offline
post #10 of 12 Old 02-27-2020, 02:32 PM
ParkerStovall42
A two jaw puller is all you need in addition to basic hand tools to do the job, it's very easy. Disconnect your battery beforehand so you don't have issues with your airbag. If pulling a junkyard wheel you can save yourself a couple bucks by not pulling the airbag or electronic switches and just swapping them from your old wheel to your new, some places are sticklers about charging for all those extras, some places don't care.
sdg3205 likes this.
ParkerStovall42 is offline
post #11 of 12 Old 02-27-2020, 04:28 PM
99wjtx
99wjtx's Avatar
What kind of beer swillin', Red-Green Show watchin' hosers would return loaner tools in such condition? Makes me want to take off, eh. I mean, you could choose not to decide whether to borrow loaner tools but if you choose not to decide then you still have made a choice. As for me, I will choose free tools!
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #12 of 12 Old 02-27-2020, 04:38 PM
sdg3205
sdg3205's Avatar
Oh take off eh!
99wjtx likes this.
sdg3205 is offline
Steering Wheel Size and Refinishing MikeyDeezy General Discussion 5 02-09-2019 05:38 PM
Steering Wheel Size & Refinish MikeyDeezy Cheap Tricks & Fixes 4 02-08-2019 05:29 AM
JK vs JL Steering Wheel Spline ? riptide JL Wrangler Technical Forum 0 01-11-2019 06:00 PM
Upholstery and Steering Wheel repair/replacement jwhutch TJ Wrangler Technical Forum 3 09-21-2018 07:02 AM
Winter is back and so is my hate for the heated steering wheel operation i20sailor WK2 Grand Cherokee Forum 11 02-17-2018 10:37 AM
