Steering Stabilizer mounts - JeepForum.com
 5Likes
post #1 of 18 Old 05-31-2019, 01:18 PM Thread Starter
OffRoadDevilD
OffRoadDevilD's Avatar
Is there a reason I don't see a lot of steering stabilizer's with mounting tabs/brackets welded on? I see ubolt clamps and other types of clamps but nothing simply welded to the tie rod. I'm building myself a 1 ton steering set up and thought, why not fabricate brackets and weld them on rather than using the clamp style mounts? Is there an easy answer that I'm overlooking?
OffRoadDevilD is offline
post #2 of 18 Old 05-31-2019, 01:28 PM
007matman
You'd weld to the adjusting sleeve?
That needs to turn to adjust it's length.
Sent from my Pixel 3 XL using Tapatalk
007matman is offline
post #3 of 18 Old 05-31-2019, 01:32 PM Thread Starter
OffRoadDevilD
The weld would replace the clamp, that's all. Everything that needs to pivot or extend would still move.
post #4 of 18 Old 05-31-2019, 01:33 PM
grayWJ4x4
1936 CJ2A
+1 on the adjustment sleeve point and also if you off road itís the first thing to hit a rock and get bent. I replaced half a dozen steel ones before I went for the aluminum route and heck I even bent that.
Clamp is the way to go my brother.
grayWJ4x4 is offline
post #5 of 18 Old 05-31-2019, 01:35 PM Thread Starter
OffRoadDevilD
You bent the steel OTK tie rod?? Jeez, yeah maybe I better keep it easily replaceable haha
post #6 of 18 Old 05-31-2019, 01:38 PM
grayWJ4x4
1936 CJ2A
Steel is easy to bend. And like I said I even bent the aluminum and that supposed to be unbendable.
In fact this post reminds me to call the manufacturer because it has a life time warranty. They say if you bend it weíll replace it.
post #7 of 18 Old 06-01-2019, 08:57 AM
97Mule
97Mule's Avatar
Here's what i got Lee...... http://www.northridge4x4.com/part/st...-clamp-1-3-8in
OffRoadDevilD likes this.
97Mule is offline
post #8 of 18 Old 06-03-2019, 01:35 PM Thread Starter
OffRoadDevilD
Originally Posted by 97Mule View Post
Nice! That thing is solid. You guys still coming out West soon Mike? You'll have to check out my new CNC plasma table. Up and running as of last night!
97Mule likes this.
post #9 of 18 Old 06-03-2019, 07:07 PM
97Mule
97Mule's Avatar
AHHHH my new best friend!
97Mule is offline
post #10 of 18 Old 06-03-2019, 07:34 PM
Magnum
Back to your original question...
I recently replaced my front end with a heavy duty tie rod and drag link setup, and it has the U-Bolt clamp for the steering stabilizer. I agree with you - it should have a permanent bracket. I am going to weld one on as soon as I have the time.
94 YJ, 4.0, 5-Spd, 33x12.5 GY Duratrac, RE 2.5" Lift
Brown Dog Mounts, 8.8 w/ disks, TrueTrac f & r
Magnum is offline
post #11 of 18 Old 06-03-2019, 07:50 PM
grayWJ4x4
1936 CJ2A
Here are the pictures of the two out of four I bent during wheeling. So even if you donít bend it while wheeling letís hope you wonít need an alignment after you weld the bracket on because thatís how you adjust the toe, and I highly doubt that bracket is going to align with the stabilizer perfectly after a little toe adjustment.
Do what I did. Move it up to the drag link. I actually have mine attached to the track bar and the drag link as you can see it from the picture.
And you can also see the little bend on the aluminum tie rod too.
post #12 of 18 Old 06-03-2019, 09:38 PM
97Mule
97Mule's Avatar
Yeah, what Gray said.........Not a good idea, unnecessary!
grayWJ4x4 likes this.
97Mule is offline
post #13 of 18 Old 06-03-2019, 09:53 PM
panzerjunky
i would be willing to bet if you weld your bracket to the center of your tie rod, You mess with the metallurgy to include the temper of the steel so I am relatively certain you will bend said rod right at your weld.
panzerjunky is offline
post #14 of 18 Old 06-04-2019, 08:57 AM
97Mule
97Mule's Avatar
BINGO!
97Mule is offline
post #15 of 18 Old 06-04-2019, 10:39 AM Thread Starter
OffRoadDevilD
@grayWJ4x4 You're a lot harder on your rig than I am
