Steering issues - JeepForum.com
 2Likes
post #1 of 39 Old 08-21-2019, 05:42 PM Thread Starter
Bugs69
Bugs69's Avatar
Steering issues
I have a 04 grand Cherokee. I put a 4 inch lift on and have had nothing but problem after problem since. The vehicle has been in the shop 5 times to try and fix death wabble. I have also installed adjustable upper and lower control arms. Have had 800 dollars worth of work done to the front end. Installed duel steering stabalizer shocks. Now i am getting another wabble. I think its coming from the steering arm. My question is this, do or should i put a drop pitman arm on???? Somebody please help me !!! This has been going on for almost a year and a half.!!!
Bugs69 is offline
post #2 of 39 Old 08-21-2019, 06:51 PM
007matman
NO! To the drop Pittman.
Check the steering box for excessive play. They can be tightened as well. Otherwise, the most common reason is TracBar play. Check got that too.
Sent from my Pixel 3 XL using Tapatalk
007matman is online now
post #3 of 39 Old 08-22-2019, 09:33 AM
jansel620
jansel620's Avatar
I don’t mean to plagiarize anyone’s threads, but I just read a great Thread titled “The Ultimate WJ Grand Cherokee Buyers Guide”. For the life of me I couldn’t find a way to link it to you in Tapa talk, so I just took snap shots of the info that could possibly help you in your death wobble journey.
Good luck to you
Sent from my iPhone using Tapatalk
jansel620 is offline
post #4 of 39 Old 08-22-2019, 04:32 PM Thread Starter
Bugs69
Bugs69's Avatar
Thanks for replys...!!
Unfortunately i have replaced almost all tie rod ends ball joints have had alignment done 4 or 5 times now... Bye the way don't take anything to TireMan !!! They didn't know how to adjust trac bar...!!!! Lol
About the only thing i haven't looked at is steering box... I am about ready to give up.
Bugs69 is offline
post #5 of 39 Old 08-22-2019, 04:50 PM
Mattyjm
Mattyjm's Avatar
What tires are you running on? Are they in good shape with even tread wear on the front? Are they balanced?
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #6 of 39 Old 08-22-2019, 05:07 PM
007matman
Aftrr a few years of struggling with mine I replaced the steering box which helped. The ultimate fix was a JKS Trac Bar and KOR Bushings.
post #7 of 39 Old 08-23-2019, 04:52 PM Thread Starter
Bugs69
Bugs69's Avatar
Tires are in good shape. I have rotated them a couple times. As far as balanced I'm pretty sure that they are.
Bugs69 is offline
post #8 of 39 Old 08-23-2019, 06:46 PM
wjpaul
Have you looked at your caster and pinion angles to see where you are with that. At 4" of lift you should have gone with long arms in order to restore the suspension geometry to keep the ride and handling good. Here's a link to one of the simplest and best vid's on long vs short arms.
Did you do your own tape measurement alignment and re-center your front axle. How did the frame mounting hole look for the track bar, if it was ovaled or oversize you would have to fix that as well.
02 GCL 4.7-QD-4" IRO CP LA lift-D44/ARB Locker-Bilsteins-Moog stabilizer-JCR slider-Falken 32x10.5
wjpaul is offline
post #9 of 39 Old 08-24-2019, 11:51 AM Thread Starter
Bugs69
Bugs69's Avatar
Ok so its up in the air and this is what we got.
Bugs69 is offline
post #10 of 39 Old 08-24-2019, 02:28 PM
007matman
Looks like you have both new upper and lower CA's
Did you check that upper CA bushing? There are two.
post #11 of 39 Old 08-24-2019, 09:22 PM
Chris Radley
Is it just me or is his adjustable track bar mounted backwards? The bend in the track bar is there to clear the center housing of the front axle, correct? If so, you might want to flip the track bar around so the adjustable portion is on the axle side and bend is over the center section of the axle. Did you property torque the TRE's and are all the bushing in the control arms including axle side of top control arms good?
Chris Radley is offline
post #12 of 39 Old 08-24-2019, 10:20 PM
SoCal2004wj
SoCal2004wj's Avatar
I looked at my WJ to compare, but it does look like the track bar is installed incorrectly. At least on my JKS TB, the adjustment nut is on the axle side and the larger bend accommodates the differential.
SoCal2004wj is offline
post #13 of 39 Old 08-24-2019, 10:49 PM
Chris Radley
I also run the JKS Trackbar but maybe they are different depending on manufacturers? Hopefully other chime in.
post #14 of 39 Old 08-25-2019, 06:25 AM Thread Starter
Bugs69
Bugs69's Avatar
Just got up n around and saw your posts. Thanks again for all the info. I just went out and checked the trac bar with the installation instructions, and as far as instructions and illustrations go i do have it mounted correctly. The adjustment nut goes on the driver side mount.
Bugs69 is offline
post #15 of 39 Old 08-25-2019, 06:55 AM Thread Starter
Bugs69
Bugs69's Avatar
Ok how about this one ? Check out the lower ball joints. Does anything look like it's missing something ?
Bugs69 is offline
