Some dash lights flash on and speedo drops while driving - JeepForum.com
 1Likes
  • 1 Post By GmanWJ
post #1 of 3 Old 09-16-2020, 06:38 AM Thread Starter
Tlando
Tlando's Avatar
This morning while driving to work, i noticed the ABS and BRAKE lights flashed on for about a second and when they did the speedometer would fall to zero until the dash lights turned off and then the speedo would go back to normal. All would happen in a bout 2 seconds time and my RPMs an driving speed never changed.
Anyone know what could cause this?? loose wire or faulty sensor maybe?
just changed spark plugs and ignition coils saturday.
Thanks in advance
Tlando is offline
post #2 of 3 Old 09-16-2020, 12:03 PM
GmanWJ
GmanWJ's Avatar
Up front ... no, I do not really know why this would happen. BUT I have read many stories about similar dash light/gauge problems and many of them talk about voltage problems. So my recommendation to you would be to check your battery, battery terminals, and battery cables. Check voltage, check for corrosion, ensure tight connections.
Then check your grounds, make sure they are CLEAN and tight. If the grounds are rusty, grimy or oil-soaked, maybe give them a thorough cleaning. There is a very good write-up about suspect grounds here: https://www.jeepforum.com/forum/f310...-info-4192594/
Should probably check all the G100's. G200 sounds like a potential culprit as well.
eljeepwj likes this.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is online now
post #3 of 3 Old 09-17-2020, 08:39 AM Thread Starter
Tlando
Tlando's Avatar
i had made sure the grounds were secure and with the on/off rain i got yesterday i just grew more and more frustrated. once i calmed down i went back to the battery and made sure the negative cable had all wires connected and terminal was clean which is usually what it is. that was no dice so i pulled the positive terminal and there lay the problem. it was coated so badly in green and white corrosion you couldnt see the terminal itself. once clean jeep fired right up and all clusters, gauges, and radio began to work again.
Tlando is offline
