Slow crank 04 4.7 - JeepForum.com
post #1 of 5 Old Yesterday, 01:48 PM Thread Starter
04wjlaredo554
Slow crank 04 4.7
Hello I have a slow crank on my 04 it only does it sometimes and it's very strange.
Battery is only a year old starter could be a issue possibly but want to see if anyone else had this I have provided a video of what it currently does.
Link: https://youtu.be/rdBY5iPxLTQ
04wjlaredo554 is offline
post #2 of 5 Old Yesterday, 01:53 PM
WJ60
WJ60's Avatar
Have you checked all connections between the battery, starter, and alternator? Sounds like an intermittent connection.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #3 of 5 Old Yesterday, 03:20 PM
cDee63
cDee63's Avatar
When mine was doing that turned out to be coolant entering the cylinder through a bad head gasket, at least I'm pretty sure that was the problem. After replacing the head gaskets it has never done it again with nothing else changed. Liquid does not compress, I figured enough was getting into the cylinder do to severely reduce the chamber volume increasing the compression in that cylinder. That's my theory anyway.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #4 of 5 Old Yesterday, 03:33 PM Thread Starter
04wjlaredo554
I will double check the terminals again and see
post #5 of 5 Old Today, 06:52 AM
Delta0
Check the voltage between your battery posts while someone cranks it for you.
Unless you have long enough meters to enable you to measure your battery voltage when you are in your car.
Delta0 is offline
