Shock nut/bolt stuck bad - JeepForum.com
 11Likes
  • 1 Post By jansel620
  • 1 Post By Bigrigr
  • 1 Post By Uniblurb
  • 1 Post By HampshireWJ
  • 1 Post By Blackwater5dad
  • 1 Post By three_jeeps
  • 1 Post By TheBoogieman
  • 1 Post By retrvrtrainer
  • 1 Post By bkanealy
  • 1 Post By ArtW
post #1 of 14 Old 04-04-2020, 01:52 PM Thread Starter
NWDC
NWDC's Avatar
Hey guys- I'm trying to pull my rear shocks and the nuts on either side are not moving at all, they seem totally fused to the bracket. Any suggestions on how to get these to move? I've already tried liberally soaking in PB blaster and using a big breaker bar... no luck. I've tried on two separate occasions to get them to move.
These look at be the original shocks on my 2000 WJ so there is a good chance that they have never been removed. I'm probably going to run into the same problem with the sway bar links as well.
What would a shop do to remove old nuts and bolts that are really stuck like this?
NWDC is offline
post #2 of 14 Old 04-04-2020, 02:17 PM
jansel620
jansel620's Avatar
Donít hold me to it, but I believe the but is welded to the bracket and the only thing that is supposed to move is the bolt itself. So if you are going to heat the nut then only wrench on the bolt side.
Sent from my iPhone using Tapatalk
NWDC likes this.
jansel620 is offline
post #3 of 14 Old 04-04-2020, 02:51 PM Thread Starter
NWDC
NWDC's Avatar
Thats good info to have, Thanks. I have only been wrenching on the nut end, i'll try putting some pressure on the other end and see if I can get it moving. None of the manuals I have say anything about the nut being welded in, which would be frustrating if it is.
NWDC is offline
post #4 of 14 Old 04-05-2020, 01:05 AM
Bigrigr
Bigrigr's Avatar
Yes, those nuts are welded to the shock bracket. I just swapped out a complete axle assembly that had that ear with the nut broken off. It was still attached to the shock, but broken off the axle bracket.
NWDC likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #5 of 14 Old 04-05-2020, 01:45 AM
Uniblurb
Uniblurb's Avatar
Exactly and heat the nut almost red hot and then loosen the bolt. Granted the rubber bushing may smoke some but you best get in the habit of heating things carefully with a torch NWDC if you don't want to snap bolts/break things. Good luck.
NWDC likes this.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #6 of 14 Old 04-05-2020, 02:50 AM
HampshireWJ
HampshireWJ's Avatar
2003 WJ
It's a nasty trick by Jeep making them look so much like a nut and washer, theres a few more places like this as well. Mine had an appointment with the grinder - not sure they enjoyed the experience, then a clean up, then treated to a new bolt, locking nut and washer.
NWDC likes this.
HampshireWJ is offline
post #7 of 14 Old 04-05-2020, 07:48 AM
Blackwater5dad
I ran into the same thing replacing the steering damper. I didn't realize the nut was welded on and it wasn't obvious. I ended cutting/grinding it off before I figured it out. Felt pretty stupid, but hey that's how we learn.
Sent from my SM-T380 using Tapatalk
NWDC likes this.
BlackwaterVB5dad
Blackwater5dad is offline
post #8 of 14 Old 04-05-2020, 11:16 AM
three_jeeps
That is because the nuts *are welded* to the frame. Just turn the bolt and you will be fine, leave the nuts alone
NWDC likes this.
three_jeeps is offline
post #9 of 14 Old 04-05-2020, 11:22 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Impact wrench will remove it in 30 seconds.
NWDC likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #10 of 14 Old 04-05-2020, 05:20 PM
retrvrtrainer
retrvrtrainer's Avatar
I broke off the bolt close to the nut with a long 1/2" breaker bar and heat. I wondered why there were three funny looking color changes on the nut when I finally got it off. As mentioned, "That's how we learn."
NWDC likes this.
Matt 7:7-11
retrvrtrainer is offline
post #11 of 14 Old 04-06-2020, 10:20 AM
three_jeeps
IMHO, it is not the best approach to initially heat the nut red hot. You should not need to. I've R&R the back shocks of 3-4 WJs and never had a problem.
If the bolt is frozen, try wirebrushing the exposed threads, soak with liberal amount of PBlaster over night, then another application next morning. Make sure you are turning the bolt in the right direction (CCW to loosen). Use an extension on the wrench if necessary. If that doesnt work, then heat as a last resort.
NWDC likes this.
post #12 of 14 Old 04-07-2020, 05:32 PM
bkanealy
1979 CJ5
If PBlaster doesn't work, try Kroil from Kanolabs.com it's pretty amazing at loosening nuts, bolts anything rusted stuck.
NWDC likes this.
bkanealy is offline
post #13 of 14 Old 04-07-2020, 11:45 PM
ArtW
I found nut does will off using a 4 foot pipe on a 1/2" ratchet. But I learned on the first one that they are welded and aren't meant to.
NWDC likes this.
ArtW is offline
post #14 of 14 Old 04-21-2020, 06:24 PM
coldspit47
Best penetrating oil is 50/50 acetone and ATF. If it can't eat through, you weren't meant to crack it loose.
There are several places throughout the suspension where the nut is welded to the frame. I always start by trying to crack the bolt free, if the nut turns, I can grab it with a wrench, otherwise I know not to waste time on the nut.
04 WJ NV242, IRO 3in, bilsteins, IRO adj UCAs/LCAs/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
